Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Problems with Panasonic PT-60LC14 60 in. Rear Projection HDTV...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Panasonic PT-60LC14 60 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Panasonic PT-60LC14 60 in. Rear Projection HDTV Television RSS Feed
View More Results for Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Panasonic PT-60LC14 60 in. Rear Projection HDTV Television RSS Feed
Answer
how can i change the antenna to cable without the use of a remote?
Answer
after geting turned off for the night, won't turn back on in the morning. will only turn on after... (More)
Answer
fan noise. like it rubbing on something internal. but the noise is intermittent, i took the rear... (More)
Answer
Where do I find the lamp bulb housing unit on back of tv so I can replace it?
Answer
I have a probem with air filter , the tv is turning off,,,any suggestions
Answer
ok so i have a 70'' panasonic rear projection tv ......replaced the bulb and now cant get the timer... (More)
Find a Manual
Panasonic PT-60LC14 60 in. Rear Projection HDTV Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Write a review:
Rate this product:
Would you recommend the PT-60LC14 60 in. Rear Projection HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Panasonic PT-60LC14 60 in. Rear Projection HDTV Television
Key Features
Screen Size
60 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Digital TV Standard
HDTV
Projector Technology
LCD
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Multibrand
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Rear Input Connectors
S-Video x 2 · Audio (RCA) x 2 · Composite x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Memory Card Slot
PC Card · SD Card
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 15 Watt
Dimensions
Depth
18 in.
Height
41.3 in.
Width
64.5 in.
Weight
101.4 lb.
Warranty
Overall Warranty
1 Year
Panasonic Contact Information
Main support number800-211-PANA
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
