20 Most Recent Panasonic AG-DV1000 Mini DV VCR Questions & Answers
F05 is better.
Panasonic... | Answered on Jan 22, 2015
That sounds good...go for it.
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Panasonic... | Answered on May 15, 2014
Hello, thanks for using Fixya.com
I would check another power source, if it still does not turn on you might have a bad fuse inside the unit witch would need to be replaced and inspected for cause of blow out.
Panasonic would take it under out of warranty bases you might want to give them a call and ask about a local factory repair shop. Most VCR and TV repairmen in your local area if you cannot find a factory service center would be your best bet.
I would not open the unit unless your knowledge fits your budget because of hazards and other occurrences can occur.
Give this website a shot for parts and service locations
Please let us know if you have any further questions,
Best regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Panasonic... | Answered on Jun 14, 2011
If you haven't got the user manual you can get it free from Panasonic's website. I assuming you want to switch it to another language?
Panasonic... | Answered on Feb 24, 2011
Examine the mechanical section for signs of damage. Such as broken plastic parts. I should treat the mode switch as possibly faulty with any vcr showing these kind of compliants.
Panasonic... | Answered on Feb 19, 2011
You have a fault with the unloading mechanism
Panasonic... | Answered on Oct 27, 2010
If I were you I would try and get a service manual for the model, this should give you the part numbers that will make it easy to track it down. Though by the sound of it the service centers sound like they want to replace the entire VCR mechanism, when it could be only one small part that needs replacing! You could hunt around on the web to see if you can get the manual free, but if you can't try Manuals in PDF.
They are very good.
Another place to try is Curry's Partmaster website. It will list all the bits for your model they stock!
True Panasonic parts supply sites are CPC and Willow Vale.
You should also list the fault on FixYa to see if the techs on here agree with the findings of the two places.
Panasonic... | Answered on May 20, 2010
The takeup spools could be faulty,not returning the tape fully.
Panasonic... | Answered on Feb 09, 2010
does the AG-DV100P have a firewire output connection?
If it does your mac should be able to 'when connected' have the driver of this machine built into the OS.
Panasonic... | Answered on Feb 03, 2010
most likely problem is a defective cassette housing.
Panasonic... | Answered on Jul 10, 2009
Main board is  corrupt.
 Check all connectios on the main board near power supply. Change the blown capacitors/diodes.
Any further help, let me know.
Thanks for using Fixya.
Panasonic... | Answered on Apr 04, 2009
if you are inputting video via the s-video connector, check to make sure the cable is good. you may be losing the color signal in the cable.
Panasonic... | Answered on Dec 10, 2008
check the main board for bad solder connections near the power connection.
Panasonic... | Answered on Oct 28, 2008
Unfortunately, all I know about Muncie is that I have relatives there. I'd go to the Panasonic website and use your zip code to locate a local authorized service center. Follow the link below and click on the "find a servicer" button in the upper right corner.
Dan
http://www.panasonic.com/support/?cm_re=1-_-Top%20Mast-_-Support
Panasonic... | Answered on Aug 20, 2008
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
I believe that this error message indicates that the heads are not spinning. The tape should be ejected. This unit requires a servicer. There are a number of reasons for the heads not spinning. Finding out the cause in your specific unit will require testing and measurements with test gear. There are no user serviceable parts inside these units. Please see an authorized Panasonic service center.
Dan
Panasonic... | Answered on Jun 03, 2008
clean the heads; often, heads that will play back a pre-recorded tape may not record because of dirt.
Panasonic... | Answered on Apr 29, 2008
Panasonic AG-DV1000 Mini DV VCR Logo
39 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
need part or repair
  • Televison & Video
