My dvd player SC-DM3 but
As you have already Unplugged the Unit ( It should be more than 60 Minutes, as this would Reset the processor ), and it did not help, so you are only Left with one trick which is Explained as follows :-
This errors usually happens because the spindle(The thing that spins the DVD), isn't moving properly. You can try this to see if that will fix it:
1) Eject the tray, and unplug the unit with the tray out
2) Remove the case
3) Locate the spindle, and spin it gently a few times
4) Put the cover back on and see if that fixes the issue
If that doesn't fix it, then the spindle will need to be replaced.
Note - There are some people saying it is the optics ( On many Search Engines and Forums ). But it rarely turns out to be the optics when that error message is shown. If you turn the DVD player on, and you can hear the disc spinning, then that would mean that the spindle is working. But if it doesn't spin up, then it might just need a little nudge.
As far as opening it, the only tricks that I can provide are general tricks to get any tight screw out. That would be to try putting a small drop of WD40 on there(Don't get it anywhere else).
Then put a screwdriver in, and tap it gently with another screwdriver handle to try and loosen it up a but. Then try opening it. Also, make sure you are using a screwdriver that is a good fit with the screw, or you will only make it more difficult to get it open.
If it's the spindle motor, then I know the part might cost between 30 - 50. Considering that labor will add to that cost, it might not be worth it. If it were me, I would replace the whole thing rather than take it to the repair shop.
If you still Wish, i could try to Search the Spindle Motor for you as i know a guy who used to sell this Motor for $42 .
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
