FixYa.com
Panasonic SA-XR45S 5.1 Channels Receiver
All Products > Panasonic > Receivers
Problems with Panasonic SA-XR45S 5.1 Channels Receiver?
Search inside Panasonic SA-XR45S 5.1 Channels Receiver Knowledgebase
Troubleshooting and Support
Solved Problems for Panasonic SA-XR45S 5.1 Channels Receiver RSS Feed Post a New Problem
DVD optical/TOSLINK input no longer...
I have had the SA-XR45 for four years now and love it. Just yesterday it stopped recognizing the optical DVD input. It's...
1 Solution
my jvc receiver has blown
my jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
STAFF 1 Solution
need harnesses & brain unit
need harnesses & brain unit for kenwood kvt-819dvd new or used need help?
1 Solution
Volume Issue with CD Player by Durabrand.
I just purchased a Durabrand CD player and every time I turn it on, the volume automatically is set at 17 which is quite...
1 Solution
kenwood receiver, and the mic input...
kenwood kr-7600 with no sound output. i plugged an elect. gtr. into the mic input that is for 'singing' along with a...
1 Solution
Sansui amp problem
I have a sansui RZ-2200AV amp which has just stopped outputting sound, the only way i can get sound out of it is to turn...
1 Solution
kvt 617 default security codes please!
best buy sold a kvt-617 to that already had a security code on it. need reset code, because i don't wan to drive two...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeReceiver
Surround SoundDolby Digital® · DTS ES® · Dolby Pro Logic II
Number of Channels5.1 Channels
Stereo Mode Power100 Watt @ 6 ohm, 20 Hz - 20 kHz, THD: 0.9%
Surround Mode Power100 Watt
THX CertificationNo
Inputs / Outputs
Rear Input ConnectorsRCA (2 Audio Channels) x 4 · Component x 2 · Digital Coaxial x 1 · S-Video x 3 · Digital Optical x 3
Surround Analog Inputs5.1 Channels x 1
Preamp OutputsSubwoofer
Rear Output ConnectorsS-Video x 1 · Component x 1 · Digital Optical x 1 · RCA (2 Audio Channels) x 2
Convenience
Tuner Presets24 Channels
On Screen DisplayWith OSD
Speaker Impedance8 ohm · 6 Ohm
Remote Control
DesignKeypad
Illuminated RemoteNon-Illuminated
Dimensions
Depth14.75 in.
Height2.91 in.
Width16.94 in.
Weight9.20 lb.
Panasonic Contact Information
Main support number800-211-PANA
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
