20 Most Recent
Rio S10 MP3 Player Questions & Answers
I NEED A driver
did you google any other sites than rio that provide a driver if so see if that helps and good luck
Trying to install a rio
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <- check this tip posted here copy the address into a new window. This will explain about your problem. Then go to Control panel -> system -> Device Manager -> and see if you have a yellow question mark or other mark there, if you do, delete the device next to the yellow mark, then at the top right click the small computer icon and chose scan for changes. Then when it finds your device chose -> portable device click ok and see if your player is in my computer now.. see the tip for modes of conectivity w/ USB devices.
Rio s10 usb cable
Take it to the nearest computer accesory store (radio shack, and ask them for a cable for it... they are plentiful (my mp3 cord works on my Razor cellphone)
MUSIC WON'T PLAY
Rio confirmed that there are fundamental problems with the firmware update, some people reffer to it as the "upgrader bug" .
You should get Rio to replace it for you, if you can't fix it with a firmware upgrade. when you talk to them, say you saw thousands of posts about this upgrader thing on the net, and you realize its a known issue.
In full sympathy,
SG ;]
Rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer.
? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer.
? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work.
? Remove USB extension cables from the connection path.
? Disconnect other USB devices.
? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode.
? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode.
Good Luck
Re mp3 wma mp3 imp 11
try deleting the files and reloading and if that dosent work make sure your putting in the proper types of files BUT im sure you are so try this first. also after deleting try also taking out the batterys overnight . Good Luck
