20 Most Recent Sony Walkman WM-FX242ST Personal Cassette Player Questions & Answers
http://www.partstore.com/Model/Sony/Sony/SRFM37V.aspx?SearchTerm=True
priced at $9.95 USD I think that's reasonable however I don't know if that's your opinion.
Let me know and I'll see if I can find a lower price
Sony Walkman... | Answered on Nov 24, 2009
try going to servicemagic.com for a repairman near you
Sony Walkman... | Answered on Jul 17, 2007
Hi, Does it eventually power up? Check all your component (ie: CD Player, Tape etc) connections and especially the connections to the speakers. If you have any loose strands of wire touching the case it will cause problems.
Sony Audio... | Answered 2 days ago
Hello Sunil, for what you comment, there may be several reasons why the term PROTECT appears on the display
There is a solution for that problem that consists of removing the humidity that forms inside the equipment, I send you the link of a video that explains how to do it
I hope you can solve the problem
Greetings Franco Dosil
Hola Sunil, por lo que comentas, puede haber varios motivos para que aparezca el termino PROTECT, en el display
Hay una soluci?n para ese problema que consiste en sacar la humedad que se forma en el interior del equipo, te mando el link de un v?deo que te explica como hacerlo
Espero puedas resolver el problema
Saludos Franco Dosil
Sony Audio... | Answered 3 days ago
If you have an older android phone or tablet, you can download an app. If not, go to any electrical or department store and buy a universal remote. You can also look on Ebay and Amazon
Sony Audio... | Answered on May 20, 2019
Yes, sometimes that is the only way. There is a reading lens and a tracking lens. Also make sure you discs are clean and not scratched. You can clean with acrylic polish.
Sony Audio... | Answered on May 14, 2019
Hi Humberto, comment the brand and model of the phono preamplifier, also if it has a separate power supply or inside the preamplifier cabinet
I ask you this, because if you were armed in a plastic cabinet, you could pick up interference caused by cell phones or other type of component that can emit electrical noise and these interferences are those that could generate the noises that you hear in your speakers at the moment that you listen to the discs
I await your comment
Hola Humberto, comenta la marca y modelo del pre amplificador de fono, tambi?n si tiene fuente de alimentaci?n separada o dentro del gabinete del pre amplificador
Te pregunto esto, porque si estuviera armado en un gabinete pl?stico, se podr?an captar interferencia que producen los tel?fonos celulares u otro tipo de componente que pueda emitir ruidos el?ctricos y estas interferencias son las que podr?an generar los ruidos que escuchas en tus parlantes en el momento que escuchas los discos
Espero tu comentario
http://diagramasde.com/diagramas/audio/Sony%20HCD-CP100.pdf
Sony Audio... | Answered on May 13, 2019
Hello, yes, supposedly you should walk, you can try without risk of something being damaged, at most it will not work
Discuss how the test was
Hola, si, supuestamente deberia andar, puedes probar sin riesgo de que se perjudique algo, a lo sumo no funcionara
Comenta como fue la prueba
Sony Audio... | Answered on May 12, 2019
Hello Giannis, the indication that appears on the screen, can be for several reasons, malfunction of cassette players, malfunction of the compactera and / or malfunction of the speaker output, in the worst case the audio output, scorched
If you have technical knowledge, you can try to disarm the equipment and go disconnecting, the flat cassette connection tape and fix if it starts, if it does not, leave disconnected and disconnect the flat tape from the compactera and the multi-legged cable that comes from the mechanism of the compactera, try again, if it still continues, you should check that you do not have direct current in the output of the STK4211
Otherwise, you will have to take it to a specialized technical service
Note, in this Sony model, you can not join the speaker negatives, since they do not have the common configuration, the audio outputs are Bridge type
I hope you can solve the problem, comment the results
Hola Giannis, la indicacion que te aparece en pantalla, puede ser por varios motivos, mal funcionamiento de las cassetteras, mal funcionamiento de la compactera y/o mal funcionamiento de la salida de parlantes, en el peor de los casos la salida de audio, quemada
Si tienes conocimientos t?cnicos, puedes probar de desarmar el equipo e ir desconectando, la cinta plana de conexi?n de las cassetteras y fijarte si arranca, si no lo hace, deja desconectado y desconecta la cinta plana de la compactera y el cable de varias patas que viene del mecanismo de la compactera, prueba nuevamente, si aun continua, tendr?as que revisar que no tengas corriente continua en la salida de los STK4211
Sino, tendr?s que llevarlo a un servicio t?cnico especializado
Nota, en este modelo de Sony, no puedes unir los negativos de parlante, ya que no tienen la configuraci?n com?n, las salidas de audio son del tipo Puente
Espero que puedas resolver el problema, comenta los resultados
https://www.manualslib.com/products/Sony-Hcd-Rxd9-3282326.html
Hello Anthony, to replace the batteries, you must disassemble the pads and remove the 3 screws of the speaker cover, there will appear the batteries
You must replace with similar batteries
re-close the speaker covers, place the pads and let it charge for 12 hours, so that the load is effective
I hope you can solve your concern
Hola Anthony, para reemplazar las bater?as, deber?s desarmar las almohadillas y retirar los 3 tornillos de la tapa del parlante, ah? aparecer?n las bater?as
Debes reemplazar por bater?as similares
vuelve a cerrar las tapas de los parlantes, colocar las almohadillas y dejar cargar por 12 horas, para que la carga sea efectiva
Espero que puedas resolver tu inquietud
https://docs.sony.com/release/MDRRF985RK_EN_FR.pdf
Sony Audio... | Answered on May 11, 2019
Google (sony)(CDP-C10)(manual) without parens.
eBay has one for sale.
https://www.ebay.com/itm/Original-Owner-User-Manual-for-the-Sony-CD-C10-CD-Player-/381420354586
Beware of search results using https://www.google.com as some sites are fraudulent and malicious that pretend to have the manual online.
Sony Walkman WM-FX242ST Personal Cassette Player Logo
8 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
older model sony walkman
  • Audio Players & Recorders
