20 Most Recent
Dell Inspiron I1545-4784crd PC Notebook Questions & Answers
No sound on dell inspiron 1545
You need to update your audio drivers. Go to my computer, check hardware configuration, locate the audio drivers and update. If you're still running vista, then good luck. You're falling down a black hole and may never hit bottom...
How do you install a hard drive
Larry provides great answer up there ^^^ which is better down here.
Larry Ng Jun 23, 2022
NO PC told (dell has 10000 models)
no OS told, windows what"?
no drive told.
my wild wild guess is the boot drive is locked.
and you are attempting and ******* act. to it.
like deleting key parts of a running OS (windows) (like deleted tires on rims of 85mph moving car, fails)
no real goal told, but the nebular "install HDD"
one can add a 2nd drive easy or any of 1000s of external HDD models or external or internal, SSD or even a thumb drive. (vast) (just 2 steps in fact)
but the boot drive , change out is far far far more complex. and you never not told that.
you want to mess with the C: drive?
now let me guess the real goal (sad I must)
the OS drive windows is failing ( common)
and some lil' bird told you it needs a new boot drive, and then fail to say so here.
okay I will bite.
1: buy a new SSD (hdd fail and are slow)
2: buy a new OS, from MS. or get free w10. (ask how)
3: then put in new SSD,
4: run the w10 installer media (it is free)
5: load w10 to the SSD fresh
6: answer the silly 30 questions it asks.
7: and click activate. (buy it)
How do i change admin password
can;t log in now or what?
what does change mean,
lost it and now can not get in
or means just want to change it , logged in.
NO PC told and NO OS told
or if bios admin or windows admin.
bios or windows.
both are hacking./ if lost.
so google the cure.
How do i eject a cd from the laptop
push the physical cd drive try button marked EJECT
the PC must be running,
or use the paper clip hole trick. (if PC is dead or tray jammed)
google that. clip trick
the dell manuals covers this
How to delete bookmarks
google dead ?
first off my PC has 4 browsers.
all 4 different answer.
IE11 ( or OMG 1 to 10 )
Edge
Chrome.
Firfox v95 (click tab book marks then click manage BM, the right click any or all you see and delete.
learn google
like
google IE11 bookmarks delete.
and read, millions of hits world wide all true.
Fix Heating issues with dell laptop
Tips to fix heating issues in Dell Laptops:
Inspect and clean the air vents and fans
Restart the computer
Update the BIOS and Chipset driver
Download and install Microsoft Windows updates
Run a hardware diagnostic test
Use Dell Power Manager to manage thermal performance (applicable for select Dell laptops)
Improve efficiency to reduce heat
Perform a Windows System Restore
Restore the computer to factory defaults
I want to delete my shtyle.fm account plz help me to delete acoount permanently
I don't know its solved or not but here's the method. Step 1 : Login to your profile of shtyle.fm Step 2 : Move your cursor to the "you option "or "your profile option". Step 3 : There, You will see the link of "Account Settings". Step 4 : Click on that link and you will see "Delete profiles and friends" Option There. Click on it. Step 5 : After that you will see the information that why you should't delete the account and bla bla bla. Step 6 : Just click on the continue button. I highlighted the link in below given image. Click there. Step 7 : Now you will see the box where you can enter the reason why you want to delete your shtyle account and profile. Enter reason or leave it blank and click on delete option. That's It. Your account is deleted. When you try to login with the same credential again you will see this. If you see below given error then your account or profile is deleted.
Source : Youshouldlisten.com
Delll Inspiron 1545 - after a bit the screen fades
I'm sure you already have checked this but it's worth a try. Did you check in the control panel area under the Power Options for how long it's set to time out the screen? Sometimes people don't know that they can change how long the screen will stay lit, then time out. In that same area you can set the time for timeout of the Hdd to sleep, closing the lid and what the power button actually does.
