20 Most Recent
Husqvarna Chain Saw Models 371, 372xp Questions & Answers
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
New 372xp seized up
Genuine cylindere and is is very expensive, there are plenty of after market cylinders available at very good prices, however you pay your money and take your chance, before fitting any new parts you need to confirm why it siezed in the first place or it is just as likley to go again.
Won't rev up
i am thinking the coil is going bad check the spark before and after it acts up
372 xp only runs on full choke. carboration, air,
There is a pulse to work the diaphram carb, this is a black pipe from the crankcase, to the pump cover on top of the carb, this feeds a positive and a negative pressure to the pump as the piston rises and falls, if the pipe is cracked, or has come adrift it will greatly effect the running
My 372xp was in use
check idle settings, if its ok check all valves and carburator assy is ok, check gaskets and sealings.
How do I take the clutch off a 576xp husqvarna?
Start by removing the c clip and washer securing the clutch drum, remove the drum,rim and bearing, there is now a special tool that fits into the clutch spider pt no. 502522201 it is a box spanner with three protruding legs and a bar across the top, i guess you could make something similar, the idea is to jar the clutch off against compression ( left hand thread ) useing a suitable hammer to strike the tool, i welded a 19 hex nut on top of the three legged tool so as to put an impact gun on ( some of these clutchs are murder tight ) i strongly advise you not to use a piston stop, or insert anything into the cylinder to lock the piston, this can easily end in disaster.
Good luck
