20 Most Recent Sony MDX-CA580 MiniDisc Player Questions & Answers
User Manual: MDX-CA580
Service Manual: MDX-CA580
Hope helps.
Sony MDX-CA580... | Answered on Apr 02, 2011
all are compatabel CD changers have only three (3) wires to hook up they work with any radio weather it is factory or aftermarket
Sony MDX-CA580... | Answered on Apr 28, 2009
Take the cd player out and run the 12+V to + on 12+V battery.
Run the Ground/Black wire to negative on battery. See if the cd player will turn on. If it does, check your ground in the dash. This is just a good trouble-shooting method to make sure the cd player system board is not fried.
Sony MDX-CA580... | Answered on Feb 09, 2009
there should be a 'source' or 'mode' button that should switch between CD and AM/FM modes. This button should also swith over to the AUX input.
Sony MDX-CA580... | Answered on Feb 04, 2009
red - switched power (hot when key is on)
yellow - constant power (hot at all times - depending on the vehicle, i've used a direct battery connection, but isn't recommended)
black - ground
blue - power antenna or amplifier 'REM' wire
the other's, i'm working off of old memory....
purple - rear right
green - rear left
white - front right
gray - front left
wires with black stripes are ground, and without are hot
- if you're working on an older car, it sounds like your red and yellow are connected to the same power source. if this is the case, the time will always be resetting.
- if it's a newer vehicle, AND the time is not resetting, the red wire is connected to the wrong source. if the time and stations stay programmed after it shuts off, the yellow wire is correct.
I had the same problem before with the same unit, and I found that the problem was only the recording format, you have to record your MDs in SP mode, this is because, the mdx-c8200 is a non MDLP MD compatible unit. So, if you want to listen your MDs on your mdx-c8200 just don t record em in LP mode, just SP mode.
Sony MDX-CA580... | Answered on Sep 13, 2008
Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Sony Car Audio &... | Answered on Jun 09, 2019
No longer listed for sale as it is old. $40 used.
https://picclick.com/Sony-Marine-Stereo-Cd-Receiver-Deck-Cdx-M501P-183497958733.html
look at Jenson Marine instead. I have one on a Boston Whaler.
https://www.jensenmarinedirect.com/
Sony Car Audio &... | Answered on May 12, 2019
+ to battery, - to ground metal in the car location where you're installing and rem to blue on back of radio.
Sony Car Audio &... | Answered on Apr 16, 2019
Sony MDX-CA580 MiniDisc Player Logo
Popular Tags
12 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
need multi plug sony mdx ca 580 fitting
  • Car Audio & Video
