20 Most Recent
Sony DVP-F21 DVD Player Questions & Answers
I need to reset a sony dvp-f21 to give standard
As far as I know, the output of your dvd is standard. If you're not getting a picture, check you have the correct audio and video leads into the correct plugs on both the dvd player and the scart adaptor, then make sure the scart is pushed fully home in the tv.
Also check that you have the correct input selected on your tv. This is done but pressing the button on your remote that has a square or circle with an arrow through it. Keep pressing it until you see your dvd.
Had one for years but now it does not even want to
This will require a good clean on the inside, POWER OFF then remove the cover clean the plastic rack with rubbing alcohol and cotton bud.
If the DVD won't spin due to trapping inside the tray you will never be able to read the DVD check to see if the tray will insert and eject usinf the button,
NOTE : never push the tray to close this can cause the tray to jump its guide dogs leg which is used to lift he head to the DVD after it has been inserted.
What does NG Disc mean
Either disc is too damaged to be read or the lazer and mirror need cleaning ( use compressed air) or the lazer needs replacement.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
