20 Most Recent
Sony SLV-D550P DVD Player/VCR Questions & Answers
Cant get my dvd player to open
As for temporary use you can use a simple method. You may see a small hole below the disc inserting cabin. Push the eject button and have a pin inserted well into the hole. the dvd player will eject in a matter of seconds.
Actually, the problem can occur as a result of aging or someone or something must have applied so much force on the player such that the dvd cabin is misplaced. If you cant find the hole, struck the top of your dvd player hard, after pressing the eject button. Two or three tries must help.
VCR Eats the tapes
Often the "Pinch Roller" type Tape Drive can "Dry Out" and it slips. this causes the tape to get all screwed up.. It could also be a belt that turns the capstan.. Or even a thing called the "Mode Switch" In any event Ya probably be best to take it in for repair as it's not really a "Homer" I suggest ya get a quote and an explanation, and see if it is economically worthwhile?
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
