20 Most Recent Sony KP-46S25 TV Questions & Answers
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/
Sony KP-46S25 TV | Answered on Dec 26, 2013
look for the power supply first, check for any bulging electrolytic capacitor.just replaced with new one with the same rating and capacity.
Sony KP-46S25 TV | Answered on Aug 09, 2012
Check this site for more details. "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
You can get details about this fault from here.
Sony KP-46S25 TV | Answered on Jun 18, 2012
Video output section has the fault. Check all the components on the video output section, which can be located at the picture tube base card.
Sony KP-46S25 TV | Answered on Apr 30, 2012
Mine had the continuous blinking , and sometimes 2 blinks after trying to turn it on again. I was given the tv and after checking it out found two blown T3.15 amp glass fuses on the audio amp. T for time delay. I went to a recycle center and bought two complete chassis for my model kp53s25. I started changing the standby power supply first. Still did the same thing. I changed the high voltage board with the smaller transformer only and leaving the other larger high voltage transformer in the set. I just cut and spliced the single connecting high voltage line between the two high voltage transformers. Still had the same problem. I change the audio board and the set would work until I believe the audio board heated up or had an intermitant short and the tv would shut down. I replaced the full audio board with another and now the tv stays on and is working great. There seems to be a overheating problem with the sony audio board and i may buy a muffin fan to fit over the audio boards large heat sinks for added cooling in the rear right hand corner of the tv . Touching the heat sinks after tv has been on a while is very warm. Find a recycle center as I bought the parts I needed for 10 dollars for two complete chassis. I should have keep the color projection tubes.
Sony KP-46S25 TV | Answered on Jan 01, 2012
Hello
Sony picture tubes are very difficult to get from open market. Just contact the nearest Sony Authorised Service center. OK.
Sony KP-46S25 TV | Answered on Apr 29, 2011
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ............... so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact sony service centre.........
Sony KP-46S25 TV | Answered on Apr 22, 2011
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule if your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Sony KP-46S25 TV | Answered on Feb 10, 2011
Confirm the voltage of G BOARD TP135V is less than
137.0Vdc.
I will post for more once your B+ is OK
Sony KP-46S25 TV | Answered on Dec 08, 2010
You will need to have a TV tech rework or replace your convergence board. Thanks for asking!
Sony KP-46S25 TV | Answered on Jun 07, 2010
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Dan
Sony KP-46S25 TV | Answered on Apr 08, 2010
#1. is the ground witch the connector can be found most likely from the crt tube ground, the one that clip with return spring.
#2. is the flyback screen voltage can be found from flyback transformer most common color is red and be insert to the hole.
Sony KP-46S25 TV | Answered on Apr 03, 2010
Try another Tv on the same aerial lead. If you have the same problem check that the UHF aerial lead plug is secure and that the centre core is secured and clean with a good strapped earth.
You cannot adjust your tuner without using specialist tuning equipment.It would be a direct replacement. If your aerial lead proves ok, check for dry solder joints on the main pcb where the tuner is soldered in. Also check for dry solder joints around the power supply and Line output stage. Next look for bulging or popped-canned capacitors around the power supply and Line output stage. The problem may not be your tuner, but a dry joint on the pcb. Gently tap the pcb with an insulated object to see if this causes the problem to occur, and you can sometimes locate the area of the problem.
WARNING: MAINS EQUIPMENT IS DANGEROUS AND SHOULD ONLY BE REPAIRED BY A QUALIFIED OR COMPETENT TECHNICIAN.
Sony KP-46S25 TV | Answered on Feb 24, 2010
If it seems to shut off after a consistent amount of time each time, check to see if it has been programmed to do so.
Sony KP-46S25 TV | Answered on Dec 30, 2009
check with maufactuer error codes and manual.. probably manual wont say .. seems like an error code.
Sony KP-46S25 TV | Answered on Dec 17, 2009
The red light blinking indicate that, something is preventing the power supply from operating:
2) High Voltage circuit has died. (Right on schedule a service if your TV is 10 years old)
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Sony KP-46S25 TV | Answered on Nov 03, 2009
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sony KP-46S25 TV | Answered on Sep 15, 2009
Picture won't come on. It clicks a couple of times then red stand by
light starts blinking
Televison & Video Logo
46 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony 51
  • Televison & Video
