20 Most Recent Sony KP-61HS30 TV Questions & Answers
Like 3D?
If so its the board that controls convergence. ( sustain 2) But the problem may have originated ELSEWHERE. so it's not just that 1 board that is at fault
However the recommendation is to change all 3 boards at the same time to avoid domino effect. Old board kills off new board!
Ther are other considerations too that need to be taken into account.. There has to be voltage check and matches between boards and Tuning of convergence chips by generating a hatch pattern. Unless you have the skills and understanding of circuit diagrams the right tools and have now had all your children ( Xray radiation +++ behind all large TV's) then I suggest calling in a professional. This is not really a DIY. Many on here think they can save a $ by DIY but 99% are back within aqweek or so with either failure orsame and even multiple other problems and still no picture.
Parts cost about $300 labour is unknown factor as I am not in USA. But generally its in vicinity of 5-700 total from what I hear on this forum.Always get a few quotes
Thanks for using FIXYA
Sony KP-61HS30... | Answered on Nov 30, 2018
Hi, Although it is a rear projection TV it will work with HD content.
You will still need a set top box to decode HD programs. This is an old TV with tubes inside and a CRT screen. They will fail and it's getting harder to get parts for. My advice go get a flat pannel TV.
Good luck
Sony KP-61HS30... | Answered on Feb 04, 2016
JUST GO IN TO SETINGS AND TEREN THE COLOR DOUWN OR TREY THE BRITNES
Sony KP-61HS30... | Answered on Apr 08, 2014
To reset it, you must have its remote control.
Sony KP-61HS30... | Answered on Feb 20, 2013
The most you will probably get out of this TV is probably 720P HD. Most new flat screen TV's have 1080P If you want to upgrade make sure you get 1080P because some flat screens nowadays are made with only 720P still. If you upgrade don't throw away the TV. Sell it, give it away, or take it to your local 2nd hand store or salvation army to help the community and the people who might need a TV. I hope you make the right decision.
By the way. If you upgrade and you have say Comcast, Dish, etc. You still need to get an HD box from them. No way around that if you want HD. Make sure the box they give you has HDMI capability or you won't be getting the full potential of the TV.
Sony KP-61HS30... | Answered on Dec 29, 2012
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
Sony KP-61HS30... | Answered on Sep 28, 2012
It uses 3 picture tubes which are no longer sold.
What is set doing or not doing that makes you suspect them?
Sony KP-61HS30... | Answered on Apr 17, 2012
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Sony KP-61HS30... | Answered on Mar 27, 2012
This set has pico fuses on convergence board and also on G power board, there should be 2 5 amp pico fuses on power board.
If convergence is bad exactly as before double check the power board fuses and check to see if voltage (it is marked!) is there with power board disconnected from chassis..
Steve
Sony KP-61HS30... | Answered on Mar 01, 2012
This most likely is convergence problem, see attached photo, do not pay for this help.
Set uses two convergence chips, they will need be replaced, less than 15 dollars for a pair.
If you are interested make a comment and I will assist you.
SD TECH
Sony KP-61HS30... | Answered on Feb 25, 2012
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Sony KP-61HS30... | Answered on May 12, 2011
Sony part number 1-453-285-21. It's not difficult to find these online. I suggest getting an original Sony part. Many of the cheap aftermarket replacements I've tried in Sony sets don't seem to work well. You'll pay a little more but the part will work. I just found this listing on eBay for one, and it's a good price.
Good luck with the repair!
Sony KP-61HS30... | Answered on May 05, 2011
This may be a problem with one or two MCZ chips....not sure if this model has them or not. Check the site www.TvRepairKits.com just in case.
Sony KP-61HS30... | Answered on May 04, 2011
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Sony KP-61HS30... | Answered on Apr 10, 2011
Sony KP-61HS30 TV Logo
68 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
remote control will not
  • Televison & Video
