20 Most Recent Sony KV-27FS13 27" TV Questions & Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sony KV-27FS13... | Answered on Jun 14, 2015
try to resolder all ic leads and power supply component, moreover Horizontal section.
Sony KV-27FS13... | Answered on Jul 17, 2013
Hello, hopefully you can help me. I just brought a used sony wega kv-27fs13 27 flat-screen tv. But when I put the cable wire in the TV it says No Signal. Do you know what the problem could be?
Sony KV-27FS13... | Answered on Apr 12, 2013
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 775 posts to different brand TVs now.
Sony KV-27FS13... | Answered on Sep 19, 2012
I'm sorry to inform you that the TV cannot be used directly with PAL color system. However, you can use a PAL to NTSC converter to resolve the issue. You can get the PAL to NTSC converter from any local Electronics Shop.
Thanks for understanding. Please let me know if you require any clarifications.
Sony KV-27FS13... | Answered on Jul 30, 2011
The problem will be in the AFT (Automatic Frequency Tunning) circuit
Check and replace any faulty parts .
Sony KV-27FS13... | Answered on May 12, 2011
no 3mm ports are there
Sony KV-27FS13... | Answered on Jan 14, 2011
Here is the master password for your TV. 4357.
If you would like the manual go the link below.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV27FS13
Good Luck
Sony KV-27FS13... | Answered on Nov 22, 2010
Hi there
In sony tv`s the 4 blink code(sony error codes)usually indicates a vertical deflection problem.
Your vertical output i.c and/or related components are probably faulty and need to be replaced.
If you feel that your up to repairing it let me know and i`ll see what i can do to help.
Merry Christmas
Sony KV-27FS13... | Answered on Dec 24, 2009
are you sure all the wires are in correctly??
Sony KV-27FS13... | Answered on Oct 08, 2009
this sounds like 60hz or 120hz a/c ripple distortion. if taping tv corrects temporarily, ther must be poor solder on main a/c ripple filter. very large usually blue capacitor near power cord input on pcb. do not short positve and negative legs together as you could be shocked(even after tv is unplugged) and also cause more damage to tv. these filters can store electrical charges for days, even if unplugged the whole time. careful! mch
Sony KV-27FS13... | Answered on Mar 09, 2009
This is an indication that the sweep power supply did not give the turn on pulse from the SMPS, thats the main power supply. If you know how to use a multimeter I will send you the instructions to troubleshoot this supply. Or you may need to trouble shoot the sweep supply as well. If you have no electronic or solid state repair experience, Please stay safe and call in a trained tech to assist you with this repair. Good Luck PS please rate this thread
Sony KV-27FS13... | Answered on Dec 28, 2008
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sony KV-27FS13... | Answered on Dec 26, 2008
Good day.
Maybe there is a problem with eigther the vertical or horizontal circuitry of your unit. blinking lights indicate a problem associated with your flyback not being able to oscillate and distribute the supply for the tuner, audio, vertical...etc..
That is an internal problem pls refer to a qualified technician.
chris
Sony KV-27FS13... | Answered on Dec 16, 2008
do u wanna repair it urself?
Sony KV-27FS13... | Answered on Oct 17, 2008
please help !!!! is it an expensive fix ? yes it is too expensive to fix it better to buy new one. as even you fix it , it will always give you problem. good luck
Sony KV-27FS13... | Answered on Aug 14, 2008
Try to press them a bit harder, sometimes they become oxidize due to non use. If there was one that is stuck, you will not get any of them to work even the power button.
Try using the remote control.
Good Luck.
Sony KV-27FS13... | Answered on Apr 12, 2008
Good day,
Yes, it has a digital tuner. It is functioning based on the command set by the buttons or signal/command from remocon.
chris
Sony KV-27FS13... | Answered on Mar 23, 2008
Sony KV-27FS13 27" TV Logo
Popular Tags
31 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
parental control password lost just
  • Televison & Video
