How do adjust for overscan compensation when a PC is plugged into the DVI port on a Sony WEga...
(More)
How do adjust for overscan compensation when a PC is plugged into the DVI port on a Sony WEga Digital TV 1080i 16x9
I have an RCA TV (don't have model number on hand) and it's only 3½ yrs old and when I turn...
(More)
I have an RCA TV (don't have model number on hand) and it's only 3½ yrs old and when I turn it on the picture is fine but after a few minutes, it fades to black for a long while but comes back for few seconds then fades back to black as though the tv is off but the sound remains perfect. I would nhave expected this from an older TV :(
I have a similar problem, however my Trinitron Model KV-30HS420 turns RED, then shuts off right...
(More)
I have a similar problem, however my Trinitron Model KV-30HS420 turns RED, then shuts off right away. Volume remains for a few seconds, then OFF. Sometimes (not always) if I'm persistant and keep turning it back on, one of those times, it will stay on with a normal picture. The TV weighs a ton and with a bad back, it's too heavy to bring in to a shop.
sony fd trinitron was working fine and the kids turned it off. Later in the day it won't turn on at...
(More)
sony fd trinitron was working fine and the kids turned it off. Later in the day it won't turn on at all. What could cause this?
After about 10 min. the screen turns green and fades to black then shuts off. The timer light keeps...
(More)
After about 10 min. the screen turns green and fades to black then shuts off. The timer light keeps blinking 7 times.
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
