FixYa.com
Sony PFM-42B1 42 in. HDTV-Ready Plasma Television
All Products > Sony > Flat Panel Televisions
Problems with Sony PFM-42B1 42 in. HDTV-Ready Plasma Television?
Troubleshooting and Support
Solved Problems for Sony PFM-42B1 42 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
where to buy pdp
hallo,i need your help i would like to buy pdp but i dont konw where and which name i should give for the compnent,if...
1 Solution
Same old PFM-42B1 problem - is it worth...
I have a Sony PFM-42B1 monitor that someone recently gave me with the dreaded "6 flash" problem. If I turn it...
1 Solution
TV Flikers and StandBy Light Flickers
I was watching TV then all of a sudden my TV went out. When I power up the TV, the TV Flickers and the red Stand By...
4 Solutions
Sony PFM-42B1E fault diagnosis
Hi there, I know this query has cropped up before, but I would like a little clarification on the subject if anyone...
7 Solutions
Noise
Hi the noise from this monitor is very loud is this normal?
2 Solutions
White picture display
while watching my tv the screen suddenly goes white. You can still see the images on he screen but they are all...
1 Solution
Tv/Monitor shuts off and on by itself
My sony 42" flat panel monitor is used as a television set using ths S-video cable as a connection. When you turn...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Sony PFM-42B1 42 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
PFM 42B1 [HELP]
When I power the unit up there is a clicking sound & a continuous red flashing from the stand by light...... the...
Post a Solution
Sony PFM-42B1
Hi, i've the 6 led flashing problem, when the fans starts the tv show for 1 sec. an noise image like "no antenna...
Post a Solution
PFM-42B1E 6 led flashing, report
Post a Solution
sony PFM-42B1E plazma screen
After short zap sound, screen went dead. Nothing works. Power supply board? How to check it? is it possible to buy one...
Post a Solution
Flashing standy light
In the menu option. FAN is in red and the display says NG. Also the standy light is flashing red whil the TV is on. Can...
Post a Solution
PFM-42B1 VGA picture is very wavy
I'm trying to get an older Sony PFM-42B1 going as a computer monitor. When I hook any computer monitor up to it the...
Post a Solution
pfm-42b problem
I have the same problem. the unit turns on and then shut off with 6 flashing red LED sign. Any suggestion for the cause...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size42 inch
Digital TV StandardHDTV-Ready
Flat Panel TypePlasma
Display Resolution1024 x 1024 pixels
Display Capabilities
Aspect Ratio16:9 · 4:3 Enhanced
Built-in TunerNTSC · PAL
Display Format1035i · 1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Remote Control
Remote ControlStandard
Image Quality
Contrast Ratio500:1
Pixel Pitch.9 mm
Brightness550 cd/m²
Output Color16.77 million colors
Viewing Angle160
Audio Features
Audio TypeStereo
Technical Features
Picture in PictureWithout PIP
Sleep TimerWith Sleep Timer
Screen Text
OSD LanguagesEnglish · French · Spanish · German · Italian
Dimensions
Depth3.3 in.
Height24.9 in.
Width40.6 in.
Weight65.4 lb.
Warranty
Overall Warranty1 Year
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
