FixYa.com
Sony WEGA KE-37XS910 37 in. HDTV-Ready Plasma Television
All Products > Sony > Flat Panel Televisions
Problems with Sony WEGA KE-37XS910 37 in. HDTV-Ready Plasma Television?
Troubleshooting and Support
Solved Problems for Sony WEGA KE-37XS910 37 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
Vertical Line 4" from left edge of...
This is type of problem seems to occur in other cases. At first, the line disappeared after the set warmed up. Now, it...
1 Solution
Help! Sony KE-37XS910 Plasma has a green...
I have had this tv for about two years and it has been working great. However, recently, I noticed an annoying problem....
2 Solutions
Sony Plasma Wega KE-37XS920 No VideoSignal
My Sony WEGA does not display a picture, either from cable, dvd, or other media. Had it fixed less than 100 days ago,...
1 Solution
Help! Sony KE-37XS910 Plasma has a...
Ive recently acquired a Sony KE-37XS910 Plasma television, it is a beautiful TV and works very well except for one...
1 Solution
Problem w/blue "bleed" on LCD TV...
I have a 42" Sony LCD Projection TV KDF42WE655 (2 years old)...just recently there seems to be some blue...
2 Solutions
Plasma TV-power light does not come on
My 42" Plasma TV has always been plugged on the outlet. Today, I found there was no red light on the TV. I tried...
1 Solution
Polaroid FLU-2632
I have just bought this tv and connected it up. The first thing I found out was that I could not configure my sky remote...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sony WEGA KE-37XS910 37 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
double picture
i have a double picture with flickering on my screen. I check all the cable conections. tryed turnning off the sat. rec....
Post a Solution
SONY Plasma Vertical Line
What did you mean by your comment to my problem with the vertical line on the right side of the screen? Thanks.
Post a Solution
Vertical Lines On Screen
About 9 Inches from left side of screen, 10 blue,red,green vertical lines on screen.
Post a Solution
Sony KDF 60" Question for you!
I see in your response that you said Sony took care of your problem with the blue bleed and pinholes! Can you tell me...
Post a Solution
Sony KE37XS910
I have a KE37XS910 and the green light on the front blinks 9x's and set never shows a pix. I suspect Power supply board....
Post a Solution
KE37XS910 sony Plasma
Have just posted a problem on Fixya and explained on there that set blinks 9x green led and set never turns on. Fans...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size37 inch
Digital TV StandardHDTV-Ready
Flat Panel TypePlasma
Display Resolution1024 x 1024 pixels
Display Capabilities
Aspect Ratio16:9
Built-in TunerNTSC
Display Format1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote ControlMultibrand
Illuminated RemoteNon-Illuminated
Image Quality
Comb Filter3DYC / 3D Digital
Viewing Angle160
Audio Features
Audio OutputVariable / Fixed
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Secondary Audio Programming (SAP)With SAP
Audio LevelerWithout Audio Leveler
Technical Features
Picture in PictureWith PIP
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsRF x 1 · Component x 2 · S-Video x 2 · DVI x 1 · Audio (RCA) x 2 · Composite x 2
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Memory Card SlotMemory Stick · Memory Stick Pro · Memory Stick DUO
Screen Text
OSD LanguagesEnglish · French · Spanish
Channel LabelsWith Channel Labels
Closed Caption on MuteWith Closed Caption On Mute
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 15 Watt
Dimensions
Depth11.26 in.
Height27.24 in.
Width44.63 in.
Weight86.06 lb.
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
