20 Most Recent Sony WEGA KLV-26HG2 26 in. HD-Ready LCD Television Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Sony WEGA... | Answered on Dec 06, 2015
Back-light fault. Contact the authorized service center. Gopakumar Gopalan Google
Sony WEGA... | Answered on May 20, 2014
Check the speaker first. Replace it with an other good speaker.
Sony WEGA... | Answered on Jan 04, 2014
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Sony WEGA... | Answered on Dec 08, 2008
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Sony WEGA... | Answered on Jan 04, 2008
OH NO!~!!! It sounds like you broke the display panel. You may be able to replace it or have it replaced but most likly it will cost more then it is worth. Inside on one of the edges is a number. Get it and look up LCD displays on the net as there are only a few major supplyers of LCD panels, and I had a freind get on for 1/3 the price that sony was asking for, and everything plugs into the display or has ribbon cables and need no alighnment after works. Good Luck PS please dont forget to rate this thread.
Sony WEGA... | Answered on Oct 23, 2006
You have this backwards. The applicable code would be in the URC, if it is compatible.
Sony Televison &... | Answered Yesterday
if possible. reinstall your vcr code in your existing remote.
consider using another remote [ set to your vcrs code ] -- remotes sometimes low cost at dollar / thrift stores.
Sony Televison &... | Answered 2 days ago
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
Sony Televison &... | Answered on May 17, 2019
It will be difficult to make a Blu-ray player region free. Anyway, visit these sites, and see whether there is any information about this.
Sir
2time is over voltage error so please replace main board
thanks
Muhammad Nasir
Sony Televison &... | Answered on May 16, 2019
Hi Laurence, from what you describe, it would look like a power supply failure, like you say a loose solder
I recommend that you be careful with the manipulation of the source plate, since there may be loads in the capacitors
When you remove the back cover, locate the plate of the power supply and look for the input capacitor (s), to discharge them, then carefully check the solders that may be loose or cracked
Also note the low voltage capacitors, those on the secondary side of the source, that are not swollen or with the top open
After reviewing and resolving the source components, reassemble and test
In some models, you also have on the Main board, small subfuentes, try to locate and review them
If after doing all this, you do not have positive results, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Laurence, por lo que describes, parecer?a una falla de fuente de alimentaci?n, como tu dices una soldadura floja
Te recomiendo que tengas cuidado con el manipuleo de la placa de fuente, ya que puede haber cargas en los capacitores
Cuando retires la tapa posterior, ubica la placa de la fuente de alimentaci?n y ah? busca el o los capacitores de entrada, para descargarlos, luego revisa minuciosamente las soldaduras que puedan estar flojas o agrietadas
Tambi?n observa los capacitores de baja tensi?n, los del lado secundario de la fuente, que no se encuentren hinchados o con la parte superior abierta
despu?s de revisar y resoldar los componentes de la fuente, vuelve a armarlo y prueba
En algunos modelos, tambi?n tienes en la placa Principal, peque?as subfuentes, trata de ubicaras y revisarlas
si despu?s de hacer todo esto, no tienes resultados positivos, busca a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
Sony Televison &... | Answered on May 15, 2019
Hello Paula, do not have video, nor sound?
I send a link of support to the Sony user, on the model of your TV
If you follow all the steps and do not achieve positive results, get close to a specialized technical service
I hope you can solve the problem, comment if it was
Hola Paula, no tienes video, ni tampoco sonido?
te envio un link del soporte al usuario de Sony, sobre el modelo de tu televisor
Si sigues todos los pasos y no logras resultados positivos, acercate a un servicio tecnico espeializado
Espero puedas resolver el problema, comenta si asi fue
https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs/kdl-60ex645
Sony WEGA KLV-26HG2 26 in. HD-Ready LCD Television Logo
Popular Tags
13 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
dark horizontal lines sony klv 26hg2 lcd
  • Televison & Video
