20 Most Recent
Sony SLV-SE730 VHS VCR Questions & Answers
I have a sony SLV-SE730 will not show any picture on my Brava Tv set does it matter what scart lead i use
First of all scart leads are notorious for bad connections. The pins can get pushed flat and not make contact. Look carefully at the connections at both ends of video and TV. Sometimes moving the socket while in the back of the TV/video will spring it into life. You can get higher quality gold platted leads if your old one plays up like this. Most TV's will have a dedicated socket for the VCR, the other being for satellite etc. In most cases it will say just below the socket. Otherwise try AV1 first.
Apears dots on a image
Try given the mechanism a good clean inside inparticular the video heads. All you need is take off the top cover and spray with Servisol Video 40 any bits the tape touches. You can wipe it with cotton buds. Allow to dry and try it out. By the way it will take longer to clean if it lives in a room where smoke is present.
Sony SlV-SE730 VCR video inserted wrong way
Unplug the VCR.
Take the cover off by taking out the small screws on the sides and on the back that hold the cover on.
With the cover off you should be able to gently move the tape back out.
Things could be damaged......after the tape is out, you should try it first with a tape that could possibly be damaged during testing and do not touch anything inside while plugged in to power during testing with the cover off!
Now......if it is not a working VCR anymore......you are in luck.
There are garage sales every weekend...and almost every one has a VCR for almost nothing....some like new.....and boxes and boxes of tapes/movies for very little money too.
While playing back a recorded programme picture is lost and AV2 appears on the tv, sound can be heard on recorded programme playing back.
Does it do so on all tapes?
It sounds like you are experiencing a tracking or tape path problem. You might try taking the top cover off, then cleaning the video head. Info is available on the 'net on how to do this. If problem remains, play a tape and see it is wandering up/down across video head. See if any of the tape guides are broken or bent, causing tape wandering.
you may also have a problem in the electronics, perhaps in the servo circuitry, which has to do with careful control of tape speed, video head rotational speed, and certain other parameters. If electronics are bad, then VCR is likely a tosser, unless it is a high $ rig. Most electronics are disposable these days, unfortunately.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
