20 Most Recent Sony SVP-5600 VHS/S-VHS playback VCR Questions & Answers
Faulty switching regulator, usually caused by dried out (aged) electrolytic capacitors. Sony part number for switching regulator is 1-413-987-11 but no longer available new from Sony - try to find a junked SVP5600 or SVO5800 (same sw reg) or you will have to try the capacitors. Make sure you use the correct types (power supply low impedance) and put them in the correct way around. ***warning - dangerous voltages - hazardous area - death or injury may result from contact with high voltages ***
Sony SVP-5600... | Answered on Aug 12, 2012
Hi Bruce, if you want to directly control your Sony KDL-37L5000 TV with your Sony RM-YD028 remote control, it should work without any problems, at most you will have to reconfigure it with the Sony TV code
I hope you can resolve your concern
Greetings Franco Dosil
Sony Televison &... | Answered Yesterday
STR-S6307 is not compatible with STR-S6707,
ON STR-S6707 YOU CAN USE STR-S6708 or STR-S6709
Sony Televison &... | Answered 2 days ago
try going into set up and reset to factory
go into setup and change region
Remote control information is included in the manual for the TV.
Hi Mike, comment why do you think you should replace the Main Board?
What defect does your Sony TV make you?
I wait your answer
Hola Mike, comenta porque piensas que debes reemplazar la Placa Principal?
Que defecto te hace tu Televisor Sony?
Espero tu respuesta
Saludos Franco Dosil
https://www.sony.com/electronics/support/televisions-projectors-lcd-tvs-android-/xbr-75x850c/specifications
Sony Televison &... | Answered on Sep 06, 2019
If you have an HDMI input it will work.
Sony Televison &... | Answered on Sep 02, 2019
The code(s) will be found in the remote control, if it is compatible.
Sony Televison &... | Answered on Aug 30, 2019
Both devices supports optical, get an optical cable.
Alternatively you can use a RCA to 3.5mm cable.
Sony Televison &... | Answered on Aug 27, 2019
Sony SVP-5600 VHS/S-VHS playback VCR Logo
1 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
faulty power supply
  • Televison & Video
