20 Most Recent
Sony DSR-45 Mini DV VCR Questions & Answers
C3120 error code. Dsr-45 sony dv deck. Any ideas
If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. Error code details of many devices are given. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]
Dv-cam dsr 80p error 09-209
This error 09-209 .It a problem with ur upper compartment,The tape did not go till the end of senor.
The best will be open upper compartment un roll manual at normal position.Then put back n power and check with menu mode
C3210 error shows in sony dsr45 ap dvcam
C 3210 is means : LOAD direction loading motor timeout,
Main region how it happen are,
1.if there is moisture in ur TAPE or if ur tape had an slack tape during search And Video head is dirty.
Best is to clean head drum or disconnect the AC power cord.
After reconnecting it,
My DSR 45 Firewire port
DSR-45's firewire port is held on a separate littlle circuit board, easily reached from the underside of the deck. Remove the bottom panel, unplug the cable from the Firewire board and there is 1 screw to hold the firewire board in place. The part is called DV-032 on Sony's Parts website and costs about £30 UK including postage to buy.
Error c:32:71
tengo un reproductor de hdv 1080i dv que me esta presentando el error c:32:71
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Error code 31:33
This type of error code ,will happen if ur have a voltage problem MD 76 board (tape sensor) .Error coming when u put STD tap or MIN tap?.Can u check the this two cable CN 1 and CN 2 MD 76 board.
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
How to connect with pc
possible solutiongiven link have owner manual please read carefully and solve your problem
www.deckhand.com/content/pdf/dsr45-brochure.pdf
