i am no getting the tv to turn on i took the back of to realine the projector but couldint find it...
(More)
i am no getting the tv to turn on i took the back of to realine the projector but couldint find it so i started taking it apart just the 3 projectors got the lens off and stop and now the tv wont tern on and i am getting a off set pitcher how do i realine the images and get the tv to turn on and can you send some pic
the color is changing...everything looks 'pinkish' . i've reset (from the manual)...i've tried to...
(More)
the color is changing...everything looks 'pinkish' . i've reset (from the manual)...i've tried to actually adjust the color...but everything and everyone looks pinkish. THE GREEN GRASS AND TREES LOOK PINKISH!
The color has gone to a red tint, the menu will not come up for me to make any adjustments and the...
(More)
The color has gone to a red tint, the menu will not come up for me to make any adjustments and the stand-by light is flashing red
My Sony KP-43T90 goes snowy for brief periods. While watching, it will slowly go snowy then quickly...
(More)
My Sony KP-43T90 goes snowy for brief periods. While watching, it will slowly go snowy then quickly go back to normal. It can happen in periods anywhere from 2-seconds to 2-hours. Other TV's are fine on the same coax and I have tried it with all peripherals detached. Any Ideas?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound Fan error 4 times - Fan1-4 Power is not supplied.(G2 board) - Fan...
written by SUPERMAN_B_1
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
