are sony big screen went out on us all it does is the red light that comes on when we turn it on...
(More)
are sony big screen went out on us all it does is the red light that comes on when we turn it on keeps blinking help we are going crazy!
was watching sony 61inch big screen and all of a sudden it just cut off. i tried to power it back up...
(More)
WAS WATCHING SONY 61INCH BIG SCREEN AND ALL OF A SUDDEN IT JUST CUT OFF. I TRIED TO POWER IT BACK UP AND THE POWER LIGHT BLINKS SEVERAL TIMES (NO PICTURE) AND IT CUTS BACK OFF. NEVER HAD ANY PROBLEMS BEFORE.
ok the tv was on it switched its self of when turned back on the red light flashing to state that...
(More)
ok the tv was on it switched its self of when turned back on the red light flashing to state that its gone into self diagnosis mode started,it fashes twice then a 2 second break and then flashes twice again and so on. does anyone have any ideas
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound Fan error 4 times - Fan1-4 Power is not supplied.(G2 board) - Fan...
written by SUPERMAN_B_1
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
