Sony KP-53S75 53 in. Rear Projection Television
Problems with Sony KP-53S75 53 in. Rear Projection Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sony KP-53S75 53 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Sony KP-53S75 53 in. Rear Projection Television RSS Feed
View More Results for Sony KP-53S75 53 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Sony KP-53S75 53 in. Rear Projection Television RSS Feed
Answer
have a Sony KP 53S75 and speaker is distorted during sound. How to remove cover to inspect and... (More)
Answer
no picture. on light blinks four times pauses and blinks four times.
Answer
no picture or audio from tv, can hear power supply turn on. timer light blinks 4 times. minor smoke... (More)
Answer
The blue is strait and the red is ok, is there any way to ajust the green, other than that pictures... (More)
Answer
I was watching my sony 52in projection screen and all of a sudden the image split. Now I get what... (More)
Find a Manual
Sony KP-53S75 53 in. Rear Projection Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Sony KP-53S75 53 in. Rear Projection Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sony KP-53S75 53 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Sony KP-53S75 53 in. Rear Projection Television
Key Features
Screen Size
53 inch
Display Capabilities
Aspect Ratio
4:3
Remote Control
Remote Control
Multibrand
Image Quality
Invar Shadow Mask
With Invar Shadow Mask
Velocity Scan Modulation
With VSM
Comb Filter
Digital 3-Line
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Energy Star Compliant
Screen Text
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
24.88 in.
Height
55.87 in.
Width
47.95 in.
Weight
149 lb.
Warranty
Overall Warranty
1 Year
Sony Contact Information
Main support number800-488-7669
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
