20 Most Recent Sony KP-65WV700 65" Rear Projection HDTV Questions & Answers
Since the set does come on try to see if it has a error buffer.
Set off and using the Sony remote: Display, 5, volume down, Power.
If it has that and comes on you should see a box in middle of the screen with several items listed-----each should have a zero to the right of it----any with a number indicates an error found and the number indicates the number of times it has happened.
Let me know what you find if anything--I can offer further help but first want to know if a error has been recorded.
Sony KP-65WV700... | Answered on Dec 08, 2012
Some of these had bad picture tubes--(model indicated here uses 3 tubes)
Simple test is go to a black and white channel and turn color to zero= is the screen black and white or some other color?
Also go to a unused video input and look at screen=all you should see is black screen with the input number in green= any other color and something may just need to be adjusted.
Sony KP-65WV700... | Answered on Apr 16, 2012
Hello sburdano,
Welcome, and thank you for using FixYa!
To answer your question: The colors are all working, they are just out of alignment.
Judging by what you have said hear, I would assume that the television have been moved, rather roughly, or bumped into rather abruptly. The color wheel will need to be re-aligned to the lamp and lens. You need to find out what your local TV Repair shop would charge for re-tuning.
Have a great day!
Sony KP-65WV700... | Answered on Dec 02, 2011
take a blow dryer blow out all the dust make sure all your connections are in good sometimes moisture causes it to do this.i hate this t.v
Sony KP-65WV700... | Answered on Jun 20, 2011
First thing to try is - do a "Convergence"
Your TV owners manual will tell you how to do this, but here's a video and instructions:
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If a "convergence" doesn't resolve the problem, repost your problem, including the information
that the problem wasn't resolved by doing a "Convergance" procedure.
Sony KP-65WV700... | Answered on May 13, 2011
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Had a similar problem ,....fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Sony KP-65WV700... | Answered on Mar 05, 2011
Re-solder convergence output ICs pins and nearby big resistors that might solve your tv picture problem and if that does not help then replace both convergence output ICs to fix the problem.
Convergence output ICs would be available in local repair parts shop or google it.
Thanks.
Sony KP-65WV700... | Answered on Feb 25, 2011
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Sony KP-65WV700... | Answered on Feb 17, 2011
that is most definately the lights have blown if it has 3 like most rear projections do but later ones have one well if it has one it is the lamp if it has 3 which i think it has it is the lamp controller i would charge 50 pounds at my store i am a tv technician so get ur local tv repair shop on the phone and there ya go it will be the controller or lap a lamp would cost u 120 and up but it has 3 im sure
Sony KP-65WV700... | Answered on Jan 20, 2011
I had a similar problem. I had a 52" RCArear projection tv. It would do this when I initially turned on the television, but then after a few "on/off, on/off, on/off" cycles it would stay on. Eventually it started doing it more; until finally there was a spark and that was it. The tv was dead.The bloggers called it "the blinking green light of death" (because of green light on the panel).The power board is going out.ALSO holding down the Input and Menu buttons afterward will give you some diagnostic information via 2 sets of blinking indicator lights.
You may very well have issues with capacitors on this set being that it is or very similar to the V26 chassis. Since I have spare test lamps laying around, I would normally try that first. If the lamp still would not stay lit, I would then suspect the electrical chassis (capacitors). When I suspect the chassis, I can usually verify it by pulling it out and partially disassemble it and find blown capacitors
Sony KP-65WV700... | Answered on Jan 12, 2011
Very common problem throught out ur DLP tv live,will happen again again many times for the tv life times.Ur tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Sony KP-65WV700... | Answered on Jan 05, 2011
I don't understand FUBR.
The problem sounds like the A1 voltage has gone low value giving poor video.
Check the HV controls. BE CAREFUL!!!!!
Sony KP-65WV700... | Answered on Dec 24, 2010
If what you see is a green line or lines on a black screen, it is the Green CRT failing. There is no real good fix for this. Sony does not support these set very much. It would require sending the Green CRT and Coupler assembly to Sony so they can mount a new CRT on the Coupler. The cost of doing this and still having 2 other CRT's that can fail in the same way makes it really a no fix.
You would be money ahead to replace it with a LCD or LED product.
I hope this helps,
Skyassoc
Sony KP-65WV700... | Answered on Dec 10, 2010
Most likely it is the green CRT that is failing. Unfortunately Sony does not support these models much anymore. What they require is to send the CRT with the Optic Coupler to them so they can mount a new green CRT to the Coupler then send it back to you. For the cost and time it takes to do this I recommend you replace the set with a LCD, LED, flat screen set.
I hope this helps,
Skyassoc
Hello, It has been my experience that once you replace any one tube of a CRT projection tube TV, the CRT that has been replaced will have more emission and it will reflect in the picture quality, I mean that there will be more definition, brightness, contrast in the blue images in the overall picture than the red and green, it will also show up as excessive in the overall gray scale adjust.
Sony KP-65WV700... | Answered on Oct 21, 2010
Sony KP-65WV700 65" Rear Projection HDTV Logo
Popular Tags
97 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
picture greenish purplish
  • Televison & Video
