20 Most Recent
Pioneer 1 to 7 DVD Duplicator: SharkCopier 1 to 7 DVD±R/RW/CD Duplicator 16X A09 with 80GB Hard Driv... (SC716XPIONEERA09) Burner Questions & Answers
I have a Pioneer CD/DVD Duplicator 8 drives.
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Pioneer AVH- p 2300 wire pinout for power plug
Here is the wire pinout for the power plug of the Pioneer AVH-P2300 car stereo:
- Yellow: Constant 12V (Battery)
- Red: Ignition 12V (Accessory)
- Black: Ground
- Blue: Power Antenna Control
- White: Front Left Speaker (+)
- White/Black: Front Left Speaker (-)
- Gray: Front Right Speaker (+)
- Gray/Black: Front Right Speaker (-)
- Green: Rear Left Speaker (+)
- Green/Black: Rear Left Speaker (-)
- Purple: Rear Right Speaker (+)
- Purple/Black: Rear Right Speaker (-)
6/25/2023 1:35:19 AM •
Pioneer...
Answered
on Jun 25, 2023
My pioneer pro 151fd TV won't play sound
- Check the volume level: Make sure that the volume on the TV is turned up and not muted. You can try increasing the volume level and see if that resolves the issue.
- Check the audio connections: Ensure that all the audio cables are properly connected to the TV and the external audio device (if you're using one). Check if the cables are damaged or loose, and try reconnecting them to make sure they're secure.
- Check the audio settings: Ensure that the TV is set to output audio through the correct device, whether it's an external soundbar or a home theater receiver. You may need to access the TV's audio settings to adjust this.
- Check the external audio device: If you're using an external audio device, ensure that it's properly connected and powered on. Try switching to a different audio input on the device and see if that resolves the issue.
- Reset the TV: You can try resetting the TV to its default settings to see if that fixes the issue. Refer to the TV's user manual for instructions on how to reset the TV.
If none of these steps resolve the issue, there may be a problem with the TV's internal audio components. In this case, you may need to contact Pioneer customer support
2/16/2023 8:56:31 PM •
Pioneer...
Answered
on Feb 16, 2023
Pioneer dvh-3490ub aux2 mode how to setup
hi
1 Press M.C. to turn AUX1/AUX2 on or off. the dimmer on or off. 1 Press M.C. to turn dimmer on or off.
- Press M.C. to display the setting mode.
- Press M.C. to select the segment of the clock. display you wish to set. Hour-Minute.
- Turn M.C. to adjust the clock.
12/1/2021 4:04:49 PM •
Pioneer...
Answered
on Dec 01, 2021
Can i download navigation to the double din pioneer AVH- P4000DVD
Sorry but no Navigation Suppourt, however you can use your iPhone or iPod/iPad's Maps or your choice of Navigation App to see Navigation Instructions and Features on Screen, compatible with Android as well. I'll attach a link and a few pics, mo Navigation Suppourt but nearly everything else. No Navigation in Menu or Inputs for Navigation Antenna on Rear with all other inputs. Check it out and see what option you like best. I'd use screen mirroring and go the iPhone route(or android if Apple isn't your preference).
Thanks and Good Luck, if this has been helpful please click the icon to let me know it has been and feel free to leave a review or follow me as I answer auto/mechanical/technical questions primarily and may be helpful again. Thanks again- Daniel
1/14/2019 4:31:56 AM •
Pioneer...
Answered
on Jan 14, 2019
