20 Most Recent Mission 783 Main / Stereo Speaker Questions & Answers
Main 5 1/4 driver cuts
probably the the wire connecting the cone and terminals at speaker are short.hold them with you fingers so that they cant move up and down with bass.if working fine then get them soldered.
8/23/2010 10:20:11 AM • Mission 783 Main... • Answered on Aug 23, 2010
Can I block out a SunPass mini to keep it from reading
take yours out of car or as steve stated
1/18/2019 3:48:34 PM • Mission Audio... • Answered on Jan 18, 2019
tip
Hand sanding wood
When sanding with a hand sanding block, I will lift the block off the surface being sanded and clap my hand onto the block to release sawdust buildup from the sand paper. I even do this when using an electric sander. The sander does a quicker job by not having to 're-sand' the sawdust that is trapped between the sandpaper and wood.
Hi I live in Belgium and bought my Packardbell
1/11/2019 6:36:15 PM • Mission Audio... • Answered on Jan 11, 2019
Got a set off mission
I would upgrade your speaker wire simply because the old might have a fault in it. Plus replacing it will eliminate it form any problems. Also check all connections for the wiring. I would recommend with second hand speakers that you get someone to look them over. Maybe what in the trade is called a "phantom dabbler" has been inside. With things such as bad soldering, or replacing a competent with the wrong part(s), or the wrong way around, or wrong connections. One way to check is to look at any case screws heads for damage, only slight perhaps. Then you know somebody has been inside before.
1/6/2018 3:02:04 PM • Mission Audio... • Answered on Jan 06, 2018
I have a mission m5as sub wondering what fuse does it take as it is internal
Why not open it up and check? My guess would be about 5 to 8 amps 25mm .
12/3/2015 2:15:13 AM • Mission Audio... • Answered on Dec 03, 2015
Mission 783 Main / Stereo Speaker Logo
Popular Tags
3 questions posted
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mission Audio Players & Recorders
Most Popular Question
main 5 1 4 driver cuts
  • Audio Players & Recorders
