FixYa.com
Tamarack ArtiScan 9600 Pro 36 Flatbed Scanner
All Products > Tamarack > Scanners
Problems with Tamarack ArtiScan 9600 Pro 36 Flatbed Scanner?
Search inside Tamarack ArtiScan 9600 Pro 36 Flatbed... Knowledgebase
Troubleshooting and Support
Solved Problems for Tamarack ArtiScan 9600 Pro 36 Flatbed Scanner RSS Feed Post a New Problem
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
How to Clean a Scanner?
1 Solution
"A HI SPEED USB device plugged into a...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1 Solution
not support window xp
acer scan 620st bit suport window xp
1 Solution
Microtek artix scan 120tf
My microtek negative scans are coming out with a very strong cyan bias, and i consistently get a light cyan strip all...
1 Solution
How to add more pages while scanning with...
Is is to possible to insert / add-on more pages, while doing scanning with Umax Astra 5600 Thanks & regards
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeFlatbed Scanner
InterfaceParallel (IEEE 1284)
Optical Resolution1200 dpi
Max. Resolution (Hardware)1200 x 600 dpi
Max. Gray Depth12-Bit Gray
Technical Features
Form FactorDesktop
Input TypeColor
Media
Supported Media TypePlain Paper · Bulk Objects (Books, etc.)
Media Loading MethodManual Load
Max. Supported Media SizeANSI A (Letter)(216 x 279 mm)
System Requirements
Operating SystemMicrosoft Windows 3.x · Microsoft Windows 95 · Microsoft Windows NT
Dimensions
Depth16.31 in.
Height3.74 in.
Width11.07 in.
Weight9.92 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
