I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part...
(More)
I have a U-Line 75 Bev and need to replace the temperature control but cannot find the correct part number. Can you help?
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet,...
(More)
I had a flash of light and electrical smell from my bar area, I moved the fridge to ck outlet, plugged the fridge into another outlet it sparked till I cut the electricity. what could cause this?This is a built in , and I saw no signs of dirt or other debris that could of caused a problem. It is a uline 75R
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating...
(More)
the norcold in my motor home works fine on propane, but not on ac or dc! could it be the heating element, or the circitoard, or what? thanks p.s. its a 1978
There is a small ledge container on the back wall of the fridge which extends across almost the full...
(More)
There is a small ledge container on the back wall of the fridge which extends across almost the full width and this is full of frozen water. Water now leaks out from botom of fridge. I am presuming the hose that drains this container comes from that ledge container. Also the container on the back of the fridge (on top of the compressor) is totally dry. I am presuming that this is the cycling part of the defrosting process. The fridge seems to work quite well other than that. Any clues? Or can you tell me how the defrost process in these works?
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same....
(More)
gss22 ifre ge refrigerator,Have new part but it is a replacement to original wiring is not the same. Can you advise how to plug it in. New one has 4 wires old one has six
We just installed a ULine 1175 BEV unit. Unless we close the door very gently and purposely, the...
(More)
We just installed a ULine 1175 BEV unit. Unless we close the door very gently and purposely, the door does not seal or pops open. Since my kids never remember to gently ease the door closed, it is usually open. Now it is flashing E5, after being open all night. Is there a way to add a stronger magnet close, or to retrofit the door so that it seals more tightly and automatically?
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
