20 Most Recent Sony CDP-CX350 300-Disc CD Changer Questions & Answers
Your drive belts are stretched out and need to be replaced. Cost 10 bucks on ebay.
Sony CDP-CX350... | Answered on Jul 12, 2017
most times skipping is caused by the laser being bad, it will need to be replaced.
Sony CDP-CX350... | Answered on Mar 03, 2016
you would probably need to have the laser replaced.
Sony CDP-CX350... | Answered on Mar 03, 2015
The gears are probally slipping Or some thing is broke on the mechanisim,Just get a different one ,It will cost you less then haveing that one repaired,
Sony CDP-CX350... | Answered on Jul 11, 2014
I too have this problem with my Pioneer PD-X77M. It will not recognize the CD in the case & goes through all six saying NO Disc.
Sony CDP-CX350... | Answered on Jun 13, 2014
The lazer is shot end not reading the info of the disc any more,
Sony CDP-CX350... | Answered on Oct 07, 2013
go to sony help support,you might be lucky and get an answer from them..they manufacture those cd players so they should know what the problem is...good luck
Sony CDP-CX350... | Answered on Aug 26, 2013
It`s a loading belt problem. The belt has to be replaced.
Sony CDP-CX350... | Answered on Nov 07, 2011
could be a simple spindle motor failure...or possibly the laser assy...the way it works is the laser needs to "see" a disc when it loads into the player. If the laser is defective, then it won't "see" a disc, thus it won't play...sony parts aren't cheap..especially if you are talking about replacing the whole transport...see if you can give the spindle a little spin with your finger and then try it...it may start working...you want to try to narrow the problem down to a single component in the interest of cost...
Sony CDP-CX350... | Answered on Oct 30, 2011
Unplug cd player from wall socket for minute to get it reset, replug back in and turn it On and check.
Let me know if problem still not solved and also check any error code in cd player display appears?
Thanks.
Sony CDP-CX350... | Answered on Jun 09, 2011
was this player loading discs before and how long have you been using the player. I suspect that the lens of your player is weak, that's why its not loading disc.
Its either the lens is very dirty, or the laser (lens) is weak.
Get a cotton board, open the player's cover with a screw driver in order to gain access to the lens, and use the cotton board to clean the lens thoroughly. After the cleaning try again.
If the player still does not load after you have cleaned the lens, then it mean the lens is weak such that it cannot be revived. In this case you will have to replace the lens completely to a new lens.
Go to any electronics accessories store within your vicinity, and get a new lens. You can remove the old lens and use it as a sample to get the new one.
Good luck.
Sony CDP-CX350... | Answered on Jul 10, 2010
Sony CDP-CX350 300-Disc CD Changer Logo
28 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony cd player skips as plays sometimes
  • Audio Players & Recorders
