20 Most Recent
Sylvania SSD803 DVD Player/VCR Questions & Answers
Has lines and no sound
I don't own this player, but it sounds like you have done the right things. Did you clean with isopropyl alcohol? Others may leave a sticky residue. Otherwise the head may be misaligned.
Have lines and no sound for my vcr
The tracking system for the tape has likely gone bad. I had a similar problem with one of my VCRs and when I took it apart, I found a very small washer that had fallen off the bottom of a roller and deposited itself on the metal bottom...I was lucky! I put it back on carefully and it's still working after about another 20 hours of use.
Disc error "playback feature may not be available on this disc"
I have a DVD and VHS player in 1 and it was working well then all of a sudden the DVD player part just stopped playing. I stick in a disk and then it would read: disk error play back feature may not be available on this disk. And this disk is fine it plays in my daughters room in her 2 in 1 player. so What can I do? The VHS player works well. Help! I dont really want to buy a new one!
How do I change EP,SP,and
As you may know, the EP,SP issue is related with VCR function (Recording ) only..
it is selectable only before recording session starts..while it plays any VHS cassette whatever the speed is , it selects automatically..there should be either a small switch in control panel or in the recording speed in "SET UP MENU "
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue for Helping out the Community :)
Problems playing a VCR tape
check/replace your vcr's belts, clean the reel sensors and check or look for bloated and deffective capacitors on power supply section,
