20 Most Recent Dell Inspiron 13R (N3010), 14R (N4010), and 17R (N7010) Laptop... Questions & Answers
Hello
Check your system with external speakers, if it gives same problem its mean that the audio drivers od the system gone corrupt, needs re-installation,
if the system gives the correct sound, means that the speakers gone damaged, need repair/replacement, you can do by your self if you are technical enough otherwise you need technical assistance from Dell Support
Good Luck
Dell Inspiron... | Answered on Nov 11, 2016
Having problem to fine a driver for my network controler
Dell Inspiron... | Answered on Mar 01, 2014
Please explain further.
Dell Inspiron... | Answered on Jan 04, 2014
There are two possible issues:
1. May be your wiring is disturbed and you need to take it to the technician.
2. And the most possible issue is that you need to upgrade the drivers of it.
Dell Inspiron... | Answered on Aug 12, 2013
You need to get a windows xp to be able to format your system very well.
good luck.
Dell Inspiron... | Answered on Jul 18, 2012
if know some one has internet go to their house and download firefox or google chrome now google one of the options and proceed to download and press save file to you will have install firefox or google chrome you must have a usb port i hope it work ;)
Dell Inspiron... | Answered on Aug 17, 2011
in that case it's either your (RAM) memory is low related to the programs that you've installed on your computer...
Try this steps to boost your (RAM) memory
Run the CMD
Then type SYSEDIT.EXE all caps
then close the two balnk window then click the fourth window
fin (enh) it has a number joining the enh press enter in front of the enh
then type Irq14=4090
then saved it after that restart your computer..... i hope that i solved your problem
Dell Inspiron... | Answered on Jul 15, 2011
Hi There,
In Windows 7 proceed as follows: (Click each one in order)
1. Start
2. Control Panel
3. Hardware and Sound
4. Mouse
5. Device Settings Tab
6. Choose touchpad from menu
7. Click Disable
To undo above, repeat the steps and click Enable
Regards,
Selk
Dell Inspiron... | Answered on Apr 05, 2011
If you want to permanently disable it, you can go to device manager and disable the driver. You can enable it if you ever want to use it again.
Dell Inspiron... | Answered on Feb 25, 2011
Hi
Yes you can get an external modem for your inspiron. Most external modem devices can be plugged in using the USB ports in your laptop.Thanks
Dell Inspiron... | Answered on Feb 22, 2011
driver or hardware problem if it is happening when using the web cam and mic then thats a good place to start update the divers for them and see if it takes care of the problem
Dell Inspiron... | Answered on Jan 28, 2011
Dell Inspiron 13R (N3010), 14R (N4010), and 17R (N7010) Laptop... Logo
25 questions posted
Clive
Clive
Alun Cox
View Most Popular
  • Dell Computers & Internet
Most Popular Question
disable
  • Computers & Internet
