20 Most Recent Sylvania 6319CE 19 in. TV/VCR Combo Questions & Answers
Yes the drive wheel gets hard and shiny after time I have had succes scoring lines into it Good luck
Sylvania 6319CE... | Answered on Sep 30, 2017
you can go and buy universal remote control. best buy or radio shack will have them in stock.
Sylvania 6319CE... | Answered on Mar 19, 2011
hi! i have here a code for your sylvania TV/VCR just try them 1145, 3095, hope this helps!!!! goodluck!!!
Sylvania 6319CE... | Answered on Jun 09, 2010
I installed systems for Directv, and whenever i went into a home that had a combo tv / vcr, i could never get a set to program properly. At the most on some sets the remote would turn the tv set on and off, but others functions were non responsive.
Sylvania 6319CE... | Answered on Dec 03, 2009
the rubber band inside for the ejecting mechanism broke. you need to take it apart and reattch with a rubber band.
Sylvania 6319CE... | Answered on Jun 13, 2008
Same exact problem with my Sylvania combo.
Sylvania 6319CE... | Answered on Jun 05, 2008
its still fixable. change the audio output ic(integrated circuit). but if you are not inclined with this job, have it check with a qualified service technician. good luck!
Sylvania 6319CE... | Answered on Feb 12, 2007
The dust had to be wayyyy excessive to any damage to the tv,it does not help but it wont hurt onless there was also water involved,if you have no indication of power (no lights ,no clicks)it might only be a fuse,if a drill or something similar was plugged in the same outlet as the tv that might have created the problem,if you are familiar with tv service or someone you know can safely remove the back and check the fuse is might be worth the effort.Just to make sure plug a lamp in the same outlet as the tv just to see if you have power coming out of it,the people working might have killed the circuit.Let Us know how it goes or if you need more information.
Sylvania 6319CE... | Answered on Oct 31, 2006
Try contacting Curtis International Customer service at 800-968-9853 and request a user manual if French.
Sylvania... | Answered on Jun 12, 2019
Does the front panel have menu, volume and channel buttons.
Here's the manual: https://www.manualslib.com > Brands > SYLVANIA Manuals > CRT TV > SRT2027 It should tell you how to do it.
Sylvania... | Answered on Jun 11, 2019
Use code search to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sylvania... | Answered on May 31, 2019
DVDs come imprinted with a region code for the geographical area they are sold in. DVD players sold in the same area(s) have the same region code. If you purchase DVDs made for a different region code, they will not play on your player. This is done to prevent piracy and copyright violators. Players can have their region codes changed, but then anything you have already will not play, and you are usually limited to three or four region changes before the player will not allow any more.
Here is a link to a Wikipedia article explaining Region Codes in more detail....
DVD region code
Sylvania... | Answered on May 29, 2019
Applicable code(s) would be found in a compatible remote control.
Sylvania... | Answered on May 27, 2019
go into input or source change to where playstation is in if no luck go to cable and channel search use 3 or 4
Sylvania... | Answered on May 19, 2019
This seems to be interesting. while using your QuickBooks software if it's showing any error or any issue then you can simply use some troubleshooting tips. if it doesn't solve the issue then you can contact to QuickBooks Customer Service https://customerservices.us/quickbooks-support
Sylvania... | Answered on May 08, 2019
Here you go! http://tv.manualsonline.com/manuals/mfg/osram_sylvania/6427tf.html
Sylvania... | Answered on May 05, 2019
Sylvania 6319CE 19 in. TV/VCR Combo Logo
12 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
sylvania combo tv vcr turns self off
  • Televison & Video
