20 Most Recent
Fuji FinePix A405 Digital Camera Questions & Answers
I cannot find a driver
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Help please -- I have
Hello
OK, you will be able to buy this USB lead at any of your surrounding camera stores. You will even be able to buy it at a computer store. Let me know if you need any further assistance.
Kind regards
\Andrea
The zoom doesn't go back into the camera
Actually this problem caused by the malfunctioning of the sled motor gears, The method to open and replace the motor and gears is technically difficult but not expensive because the lens block assembly repair in most models in fuji is available. Therefore, contact any expert to rectify the problem.
Thanks for using fixya.
Maximum xD size supported?
here is a link to Fuji's web site for memory card compatibility:
http://www.fujifilm.com/products/digital_cameras/accessories/card/index.html#compati
Outside shots just come out white
Or do you mean a white mare?
Check your manual to make sure that a setting has not been over looked.
It seems as if the light metering has gone askew
You should also check that you are not covering a 'window' with a finger when taking shots- thus blocking the light thus making it read low light.
If all this is to no avail - check out the Fuji technical help team.
But give much more detail than you have given us here
Focus error finepix hs10
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping.
In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus.
The solution is to disassemble the camera and secure the screws.
These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered.
Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board.
Those who want to try the repair, follow the link to the service manual.
http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html
Milton Maenishi
I have a FinePix S1 and the display screen is not working. All other modes are working but no display
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
