20 Most Recent
Fuji FinePix A303 Digital Camera Questions & Answers
I mistakly delete my pictures
All your pictures are saved on the memory card of your digital camera automatically.So you can recover your deleted pictures from memory card with third party data recovery software.I have a professional program on my computer that can recover data after deeply scanning your memory card to look for lost data you accidentally deleted or formatted. By the way,you can download it and scan your memory card for free to preview whether your erased pictures can be recovered. Get it from
http://www.any-data-recovery.com
How do i delete memory card
In photo mode (not in view mode) there is a 'format' function under 'Menu'. This erases everything on the memory card, so transfer the pictures you want to keep to a safe location first.
A download link for the manual of your camera is provided below.
Have fujifilm finepix f40fd. protected card shows. wont clear
I had the same problem with a Fufifilm camera. When I looked closely at the memory card I noticed a little white sliding button on the left hand side. When it is in the down position the card is locked or protected. Just slide the button up and put it back in your camera and it should work.
Need to cahand language china
Press the MENU/OK button to bring up the menu. Press cursor-left to move to the tabs. Use cursor-up/down to select the SET tab (wrench icon). Press cursor-right to enter the setup menu. Use cursor-up/down to select the item with two Chinese characters, a slash, and "LANG" (speech-bubble icon).
I have lost my disc for my camera where can i
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
We have message = zoom error
1st replace it with new batteries. if the zoom lens is coming out and going in after putting on and off.if not then dust is the problem. while putting it on try to pull the lens slightly or if it out then try to press in slightly if doesnt work then replace lens unit
I plugged my FujiA303 usb into my new MAC Book Pro
do you have a sound cards in your camera where you can take out the card and put it into a computer. try this buy a card reader and put the card into the reader and hook it up to the mac, (which I have ) and maybe they will show up. you have a program on the mac called i photo and thats how i do my pics, but if it doesnt show then yes u prob lost them but try this. it may work good luck.
Only turns on to ONE SETTING!!!
I guess you got a serious problem with your camera. The camera you have a problem that I said bad induction in the motherboard camera. The solutio, you have to replace your maiboard with the new one. So, bring your camera to the service center.
