20 Most Recent
Emerson SA-100 Car Subwoofer Questions & Answers
Are these speakers any good?
These would make great secondary subs if your going for an elaborate install, but in the end even cheap no name subs will sound good if coupled to a good amp. The best way to know is to test them, push on the cone and feel it's resistence, if it feels tight, they should pound, if not, be careful.
I have a Emerson 6 disk CD changer. The door no longer opens and its making a funny noise. What can be wrong with it?
If your Emerson 6-disc CD changer's door is not opening and it's making a funny noise, there could be a few possible causes:
1. Mechanical issue: There could be a mechanical problem with the CD changer's door mechanism. It's possible that a part has worn out, become loose or broken, preventing the door from opening. The funny noise could also indicate that something is stuck or jammed.
2. Electrical issue: It's possible that there is an electrical problem with the CD changer. There could be a faulty connection, or an issue with the motor that drives the door mechanism.
3. Dirty or dusty: It's also possible that the CD changer's door mechanism is dirty or dusty. Over time, dust and debris can build up inside the changer, making it harder for the door to open and close.
To fix the problem, try these steps:
1. Unplug the CD changer from the power outlet and wait for a few minutes before plugging it back in. Sometimes, this can reset the CD changer and fix any software issues.
2. Try manually opening the CD changer door. Look for a small hole or slot near the CD changer door. Insert a paper clip or a similar object into the hole and gently press down. This should release the door lock and allow you to manually open the door.
3. If the CD changer door opens, check for any CDs that may be stuck or jammed. Carefully remove any obstructions and try again.
4. If the CD changer door still does not open, there may be a mechanical or electrical issue. In this case, it's best to take the CD changer to a qualified repair technician or contact Emerson customer support for assistance.
Remember to always exercise caution when attempting to repair electronic devices. If you are unsure about how to proceed, seek the help of a qualified professional.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
