20 Most Recent
Apevia iTEKIRO Replacement Netbook AC Power Adapter Laptop Charger (ACERASPIREONEZA3ADAPTER) AC Adapter for Acer Aspire One ZA3 Including 2-Pron... Questions & Answers
Aspire 4736z422g25mn
unplugged the cable, and pull out the battery for a few minutes, like a 15 min and conect all and try, its the problem persist change the internal watch battery
Aspire one d2500dr
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.From the sounds of it, you probably did one of the two and now you cannot connect to the Internet. If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
No working windows8 driver
Being a new OS the drivers are available for older systems or devices, sometimes you can use win 7 drivers 32 or 64 bit. The problem may be you have to modify the drivers to work with your specific machine. I had to do the same when I upgraded a Gateway MX6421 (born in 2005) to Win 7 pro N 64bit, I modified a few lines of code in the driver and changed the drivers compatible to win 7.
Acer4752 sound problem
You can connect a powered stereo speakers to your laptop for better sound. Connect an audio cable from the headphone socket on the laptop to the powered stereo speakers.
