20 Most Recent Apevia iTEKIRO Replacement Laptop AC Power Adapter Notebook Charger (ACERTAC090W008T7M310) AC Adapter for Acer Aspire 5532 5532 5534 5535 553... Questions & Answers
Go to Control Panel and check it about the drivers.. if there is change the options.. otherwise install the touch pad drivers...
Apevia iTEKIRO... | Answered on Apr 03, 2014
Battery not charged. Bad connection at power adapter plug. Bad power adapter.
Apevia Computers... | Answered on May 25, 2014
Press F3 It should have a keypad emblem with an x across it.
Apevia Computers... | Answered on Jan 23, 2014
unplugged the cable, and pull out the battery for a few minutes, like a 15 min and conect all and try, its the problem persist change the internal watch battery
Apevia Computers... | Answered on Nov 25, 2013
I assume you're running Windows 7 or 8. In general, you can't uninstall wifi--but you can certainly turn off your antenna (usually a switch on the side or front of the laptop) or you can tell windows to forget about a particular network.
From the sounds of it, you probably did one of the two and now you cannot connect to the Internet.
If you want explicit instructions, I need to know which version of Windows you're running (XP, Vista, Windows 7, or Windows 8).
Apevia Computers... | Answered on Oct 18, 2013
Perhaps it's the backlighting or the switch that controls the on/off of the display when the laptop lid is opened/closed. Take a look at this video to help troubleshoot: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Apevia Computers... | Answered on Jun 08, 2013
Post to TV category.
Apevia Computers... | Answered on May 30, 2013
Hello, on ACER 7736zg motherboard, the mosfet U58 of type si4812BDY fails very often, which causes the symptoms you describe. Tutorials are available on youtube for changing this chip yourself (<1$)
JP
Apevia Computers... | Answered on Apr 03, 2013
inside most laptops/ pc have to be opened up depends on you make/model
Apevia Computers... | Answered on Feb 08, 2013
Being a new OS the drivers are available for older systems or devices, sometimes you can use win 7 drivers 32 or 64 bit. The problem may be you have to modify the drivers to work with your specific machine. I had to do the same when I upgraded a Gateway MX6421 (born in 2005) to Win 7 pro N 64bit, I modified a few lines of code in the driver and changed the drivers compatible to win 7.
Apevia Computers... | Answered on Nov 05, 2012
It may be hardware failure (bad hard disk, memory or CPU for example).You can boot your system using windows XP CD.....
If you need any kind of technical assistance , you can contact support cell at http://www.vtechsquad.com
Apevia Computers... | Answered on Sep 07, 2012
You can connect a powered stereo speakers to your laptop for better sound. Connect an audio cable from the headphone socket on the laptop to the powered stereo speakers.
Apevia Computers... | Answered on Jul 02, 2012
Apevia iTEKIRO Replacement Laptop AC Power Adapter Notebook Charger (ACERTAC090W008T7M310) AC Adapter for Acer Aspire 5532 5532 5534 5535 553... Logo
1 questions posted
Top Apevia Computers & Internet Experts
 Mike M
Mike M
Paul Carew
Harrie
Are you an Apevia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apevia Computers & Internet
Most Popular Question
touch pad not scrolling
  • Computers & Internet
