20 Most Recent Pavilion DV5000 DV5100 DV5200 Series Laptops Questions & Answers
Fix a HP DV5200 that will not boot
faulty CPU most likely. take the CPU out and get a replacement from EBAY etc. get some isoproyl alcohol and some thermal paste from there too. warning: you will need to reformat your hard drive as the BIOS settings will most certainly be different and you will probably get the BSOD (blue screen of death) by trying to cold reboot from the same hard drive. back everything up first. take the hard drive out and get a caddy and backup to another machine.
3/7/2012 4:36:32 PM • Pavilion DV5000... • Answered on Mar 07, 2012
2answers
Desktop 24-b114 need help with power-on password key
he said power-on password not windows clear as day it is the BIOS admin power on password so both are lost, power on and admin bios both I bet. and this is hacking. BIOS. (well not really in this case) HP told you no, so come here. sure. first off it is a desktop not a notebook or LAPtop most Desktops have jumper marked CLR_PW the manual for your PC covers that act. oops a daisy it is AIO, all in one FAKE desktop wow the answer is in the book at HP. https://support.hp.com/us-en/document/c05121421 learn to read the manual first, then post ? mobo HP name: Saipan-UF to be frank is look at all Desktop mobo for jumpers, 99% they are there, then I think gee this is in the manual. and is. pw-undefined-undefined-0.jpg how to do it my guess is, jumper5>6, power on , count 1 min, power off and remove 5>6 now PW gone. leave 7 to 10 alone.
3/5/2022 8:32:12 PM • Pavilion... • Answered on Mar 05, 2022
2answers
Factory reset a pavilion dm1 laptop its not working right and I need it for school
reset does that mean reset windows., yes then say winDOWS. DO YOU HAVE DATA TO LOSE. ?NOT TOLD. dm1-1010ef SEE THAT A REAL MODEL TOLD, sadly BUT NOT YOU. THE ANSWER IS AND FOR SURE ASK HP THIS ! OR on your dm1 support page dm1-NNNNLL , RTM READ THE MANUAL and the chapter called RECOVERY. There are 3 ways to recover on most PCc. off dvd disk from HP or out of the box OOBE new (lost?) made a dvd using the hP make recovery disk. method make. or from the HDD recovery image if hdd is not bad this works. hp.com has a real fourm there under support. why in the world not ask them. sometimes they even have free or cheap recover disk to sell hint 1: we have NONE.
3/5/2022 8:32:04 PM • Pavilion... • Answered on Mar 05, 2022
How do I turn on my pavilion x2 10t laptop
push power button 10 seconds release it if dead , remove huge battery makes sure powerpack AC/DC is not dead and push 10 seconds again.
3/5/2022 3:59:10 PM • Pavilion... • Answered on Mar 05, 2022
What memory does a Pavilion Slimline S5000 PC use DDR, DDR2, DDR3?
that's easy but no full model told quotes (sales)_ "HP launching its new s5000 series in June of 2009 In total there are eleven HP Slimlines which have been released "then ! learn to read the service tag first read the true model name and product ID then answer be accurate the what matters is the CPU it uses and what north bridge it has. and some bridges do ddr2 and 3 but the maker chose 1 or the other.. See, and PC are not the same sold all over the earth. not told that ether, old g41 chip set if intel version/ if is g41 it does in fact support DDR2 and 3. only HP decided what to use, only them, their DESIGN no model told at all S5xyz1 , zyz1 not told at all so not answer easy. ever./ or go to Hp.com click support and tell real model now. and RTM s5305z, s5310t, s5350z, s5370t, s5380t, s5730f, s5220y s5530 and more. endless it seems. S5510,s5100br,5507,5160 5260 and more, lost more and more world wide, worst of all support ended HP' and wiki says it loves to overheat. the end letter are for country or sold in special stores, like walmart bestbuy, all numbers in the model or product ID matter, stated on he service tag.
3/5/2022 3:59:06 PM • Pavilion... • Answered on Mar 05, 2022
Go pavilion 750 video is going out
2022 questions. did it every work for you before now? and did PC move to different rooms or home? is this a desktop???????? you said MON so is. as old as 2018? this????????????? HP ENVY Desktop , 750 HP ENVY Desktop - 750-170se CTO?????? true name found. unplug both PC and mon from wall AC power for 15 mins walk the dog come back, and turn on PC first then monitor last the PC fans must spin and blow air. CPU and PSU both. the PC power lamp glows as the manual on PC tells. solid color. PC video cable connected to MON, if PC has video card, only those jacks work now. turn on MON, next. (AC BACK) if PC is dead (video) the MON will error out as NO SIGNAL no connection (THEN GOES TO SLEEP) no monitor model told or what cable used. VGA, DVI, HDMI or DP./?????? this PC is sold in vast sub models no told by you see that 750-170 above the 170 is the sub model codes vast. they are not all the same and I can not see the rear of PC nor MON jacks but in the MONITOR, PUSH MENU KEY, THERE FOR OSD AND TELL THE MONITOR WHAT VIDEO JACK OF 4 YOU HAVE CONNECTED TO THE PC. ALL connections and all sounds and LED states matter. and screen errors. and all blink codes of LED matter and fans blow. all that matters.
1/13/2022 1:56:37 PM • Pavilion... • Answered on Jan 13, 2022
After windows 10 upgrade and driver being loaded computer still not seeing audio card on pavilion computer with beats audio
Chances are if you supply Larry Ng with the information he requests, he will find a way to assist. He is very knowledgeable. Here is a link indicating that your experience of losing recognition of an audio card is far from an isolated occurrence. It offers procedures which may or may not help. But my best advice would be to supply Larry with what he is requesting. https://answers.microsoft.com/en-us/windows/forum/all/sound-card-not-working-after-upgrade-to-windows-10/fb8cd9a6-a643-4ff8-85f3-ecff99afd7e0
1/11/2022 3:30:30 AM • Pavilion... • Answered on Jan 11, 2022
How do i install netflix on my pavilion dv6-2150us notebook?
windows what version.??? its not a TV sorry all you do in any PC is Launch the PCs OS browser or better, firefox v95 ,installed. the go to URL www.firefox.com log in and done. works with Edge, Firefox new, , chrome new, and IE11 but not IE 1 to 10. ever all these are banned now. and had to load Install the Microsoft Silverlight Plug-in.
1/10/2022 4:17:16 PM • Pavilion... • Answered on Jan 10, 2022
0answers
3answers
Pavilion a1129n will not start No power supply light either. Fuse?
"I have the ability to repair the power supply, with some guidance. It's no different than a power supply in a stereo system, or, realistically, nearly every electronic device that uses a transformer to reduce voltage. I'm not afraid to take it apart and check the components. I'm just looking for smart place to start the diagnosis." PSU on any PC desktop made can be bench tested. easy or more complete with tools. many parts in any PSU have custom contract parts (a secret) SO ABILITY IS SUPER LIMITED ON PSU. MAKER NOT MODEL TOLD OF PSU./ The Psu has fuse deep inside, some are hidden in the transformer, too. if blow out now the F1 fuse the fuse blows 99%^of the time replaced due to other parts are shorted,most you can not buy but caps yes and easy. the fan dead tells you the +12vdc rail is dead (at least) here is the bench test (forget PC for now)_ jumper test and more. https://pcdied.com/PSU/power.html#the_jump_start_magic the PSU needs a good cord AC. not dog chewed. it needs AC power not dead. at the wall No funky power strips . yes monte said check wall power, I use hair dryer,wifes 1500 watts is great test for any wall jack AC 15/20amps / and first the old silly 115/230 switch not seen today. this PSU is SMPS unlike cheap home stereo gear. as seen here great examples https://pcdied.com/PSU/schematics/html/image_1.html your day1 new OOBE PSU was 300watt hp # 5188-0129 here it is day1 new, shown at hp partsurfer.com 129-undefined-undefined-0.jpg avoid electric shocks seen here. https://pcdied.com/PSU/schematics/images/bridge-hv-ouch.jpg
1/2/2022 4:56:42 PM • Pavilion... • Answered on Jan 02, 2022
2answers
Factory reset pavilion dv7 Windows vista and now it's asking for a password and it says the administrator account has been disabled
I was long time since I used Vista. Try the following. During pc booting keep pressing f8. Keep pressing not one continues press. If that doesnt work use f10 or f2. One of them will work and you will be able to log to your hidden administrator account
1/2/2022 4:08:27 PM • Pavilion... • Answered on Jan 02, 2022
2answers
My question is she I turn on my pavilion dv7-3057nr Entertainment notebook why does it comes up diagnosing your pc
This notebook came with Windows 7 Home Premium. You have not indicated which OS it has. It appears to have a corrupted registry. You may be able to address the issue by entering safe mo tapping F8 on bootup and performing maintenance there, such as trying a system restore point. Barring that, you may have to use recovery options that reset the computer to factory fresh condition. https://support.hp.com/us-en/document/c01902007 https://support.hp.com/us-en/document/c01867418
12/28/2021 5:09:33 PM • Pavilion... • Answered on Dec 28, 2021
How do I reduce the size of my screen
Get a new monitor. Or trade with somebody who wants a bigger screen, which most people would.
4/6/2017 5:13:46 PM • Pavilion... • Answered on Apr 06, 2017
Pavilion DV5000 DV5100 DV5200 Series Laptops Logo
1 questions posted
Top Pavilion Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Pavilion Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Pavilion Computers & Internet
Most Popular Question
fix hp dv5200 will not boot
  • Computers & Internet
