20 Most Recent Haier HTF27R11 27" TV Questions & Answers
Without the remote, some TV's are useless.  Is there a menu button on the TV itself?  If so, you will have to determine what buttons do what.  For example, volume up and down may let you scroll through the menu while channel up and down may let you go left or right in the menu.  If you only have volume, chanel and input/source buttons, you may need to order a new remote to solve this.
Haier HTF27R11... | Answered on May 18, 2018
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Haier HTF27R11... | Answered on Jun 21, 2016
I have exactly the same problem! PLEASE HELP ME!!
Haier HTF27R11... | Answered on May 02, 2016
what is the problem. is your remote is not working or you have only blue screen. hope you will clear it.
Haier HTF27R11... | Answered on Aug 29, 2015
Main system control memory IC damaged. Replace it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Haier HTF27R11... | Answered on Aug 07, 2014
Video output section circuit fault. Contact any service technician to get it repaired.
Haier HTF27R11... | Answered on Aug 02, 2014
To know more about how to enter service mode to this TV, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Haier HTF27R11... | Answered on Sep 25, 2013
Check and replace the final anode cap. It is leaking. If you wish to get more details, check this site. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Haier HTF27R11... | Answered on Sep 11, 2013
Just try a hard reset first. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. It must make it a hard reset. If it do not help you, replace its main system control memory IC. It will look somewhat like this, and will have 8 solder terminals.
Haier HTF27R11... | Answered on Jul 09, 2013
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Haier HTF27R11... | Answered on Apr 14, 2013
Change the picture aspect ratio. Refer its user manual for details.
Haier HTF27R11... | Answered on Jan 24, 2013
You must have its remote control to select inputs.
If power supply is OK, and standby light is ON when you power ON the set, the main digital board is likely to be faulty.
Haier HTF27R11... | Answered on Jan 13, 2013
Click here to download its user manual. It have all details about how to select HDMI and other video inputs.
Haier HTF27R11... | Answered on Jun 24, 2012
Some tvs could do reset the setting,by unplug,replug it back like 24 hours later.This is a hard reset no power tv power source,will reset everythings in most tvs.
Haier HTF27R11... | Answered on Mar 22, 2011
Haier HTF27R11 27" TV Logo
59 questions posted
Top Haier Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Televison & Video
Most Popular Question
remote 4 digit code haier tv
  • Televison & Video
