When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show. Log in as "Administrator". Click Yes to not use System Restore Mode. Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
If all else fails you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard
Many RTC's require an external battery. If your RTC is one of this type you can clear the BIOS password just by unsocketing the RTC and reseating it
click start type cmd press enter.-Type control userpasswords2 then press enter - With the User Accounts window open click on the Users tab.- Clear the box that reads "Users must enter a user name and password to use this computer." and click Apply.- A window will appear asking you to enter the name and password for the account you want to automatically log into.- Once you have entered that information click OK to close out of that window and again click OK to close out of the User Accounts window.
this will vary depending on your operating system
Hope it helps
5 questions posted
5,472 Questions
2,719 Questions
2,468 Questions
2,231 Questions
2,165 Questions
