dear sir, ı have dvp630 philips player.it is not working divx dvd in the that...
(More)
dear sir, ı have dvp630 philips player.it is not working divx dvd in the that player.why.thanks
philips dvp630 dvd player, no power, have chenage both the plug fuse and the fuse inside the dvd...
(More)
philips dvp630 dvd player, no power, have chenage both the plug fuse and the fuse inside the dvd player, any ideas
I have a magnavox 26MD255V/17. The built in DVD player keeps ejecting the DVD's. If I try it long...
(More)
I have a magnavox 26MD255V/17. The built in DVD player keeps ejecting the DVD's. If I try it long enough it will take but it can be as many as 30 times trying to push in and the unit ejects shortly after loading. It does work after enough tries
blue screen and no pictures any chances reset dvd player in originals setings, no menu tables on...
(More)
blue screen and no pictures any chances reset dvd player in originals setings, no menu tables on screen. i cant see what am presing
My DVD has the on/off (standby light) on red and the power ligt is green, but it will not budge. It...
(More)
My DVD has the on/off (standby light) on red and the power ligt is green, but it will not budge. It is as if it is stuck. I have tried disconnecting the power, but it doesn't do anything.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
