Philips DVD727/17 System Option was set to PAL...Now no picture and remote system menu button seems...
(More)
Philips DVD727/17 System Option was set to PAL...Now no picture and remote system menu button seems disabled. How do I recover my use of DVD player besides unplugging it then power up.
I was fumbling around with this dvd player (2nd hand), and mistook the disk lock for a function that...
(More)
I was fumbling around with this dvd player (2nd hand), and mistook the disk lock for a function that might hold my place on a dvd when off. Now, I can't unlock the player. Since it is an older unit, and 2nd hand, the password is long forgotten. Is there a way to override this? Because right now it's essentially a paperweight.
see when i was wacthing this movie ''back to the future'' the dvd just stopped playing and i knew...
(More)
see when i was wacthing this movie ''back to the future'' the dvd just stopped playing and i knew something was wrong, so i open it up and to my suprise the dvd is almost half way in the dvd player. any ideas?
checked all the wiring and connections and they were fine. It actually started after watching 2...
(More)
checked all the wiring and connections and they were fine. It actually started after watching 2 dvd's.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
