20 Most Recent
Philips DVP3050V/37 Questions & Answers
Vcr makes knocking sound then shuts off
Is that when you insert the tape? Try ejecting and inserting a few times to see if you can "unstick" something that's stuck. If that doesn't work, you're probably going to need service. VCR mechanisms are usually driven by belts that dry out with age and can start slipping or breaking. It's going to be increasingly difficult to keep a VCR going in today's world. Service will get expensive and rare and parts hard to find. See if you can just buy a new one. Otherwise, get a DVD player and have any precious videos converted to DVD. It's only a matter of time before VCRs disappear entirely.
3/31/2013 7:44:35 PM •
Philips...
Answered
on Mar 31, 2013
My Phillips DVD 3050V/75 will
You will need to remove the top cover of this DVD player to remove the disc from the Drive tray. Always unplug the unit before servicing. Be careful to not touch the sensitive electronics. Remove the disc and put the unit back together exactly how you took it apart. There should only be a few screws on the back and sides of unit, holding the case of the unit to the frame and front cover. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
5/17/2011 8:28:19 AM •
Philips...
Answered
on May 17, 2011
CD disk tray is stuck in closed position. Manual
Most likely mechanical.
There are many possible reasons for why the drive won't open.
1. the drive mechanism is stuck.
2. the motor that moves the tray is broken
3. the flat cable that transfers movement from the motor to the other gears is out of place
I'll
stop there, If you are outside of warranty, you may take apart the dvd
player, if you are in warranty, then just try unplugging the dvd player
for 5 minutes and then try again.
If your outside of warranty and your prepared to take it apart, unplug all the cables and unscrew the screws to get the top off.
Inspect
the drive, and try to help it eject by rotating the gears in the drive,
they might be a bit difficult to move as they may be hidden under the
tray, find a way.
Once you get the tray to release the problem
might be solved, inspect the gears and the rubber transfer cable from
the top of the motor to the other gears that it in place and moves
freely.
Put the power back on, don't touch anything inside the
player while its plugged in. Now, see if the ejecting and inserting of a
disc works properly. If it does, unplug and reassemble the unit, the
problem is solved.
11/8/2010 2:51:41 AM •
Philips...
Answered
on Nov 08, 2010
This is stupid but I
I assume you wish to set the VCR (model DVP3050) clock. This is easy, just follow these instructions:
- Press VCR, then press DISC/VCR MENU so MENU appears. If the clock has never been set, the CLOCK SET menu may appear when you press DISC/VCR MENU. If so, follow the instructions from step 3 on this page.
- Press \/ or /\ to select CLOCK SET.Then, press >.
- While the MONTH space is flashing, press \/ or /\ until the month appears.Then, press >.
- While the DAY space is flashing, press \/ or /\ until the day appears.Then, press >.
- While the YEAR space is flashing, press \/ or /\ until the year appears.Then, press >. The day of the week will appear automatically.
- While the HOUR space is flashing, press \/ or /\ until the hour appears.Then, press >.
- While the MINUTE space is flashing, press \/ or /\ until the minute appears.Then, press >.
- While the AM or PM space is flashing, press \/ or /\ to point to AM or PM. Your selection will flash on the screen in the AM/PM space.
- Press CLEAR/RESET or > to start the clock.
And you can now have an online manual,
click here. (Adobe pdf required) Directions on page 22.
Lots more Info
11/7/2010 9:34:43 PM •
Philips...
Answered
on Nov 07, 2010
VCR wont record
Youmay very well have a capstan drive problem that could be resolved by either replacing or even just cleaning the friction surfaces...accordianman
2/15/2008 3:48:56 PM •
Philips...
Answered
on Feb 15, 2008
Recording from vhs to dvd
i am pretty sure you can not.....unless it is a dvd burner too which i am pretty sure it isn't then no you can not record vhs to a dvd with that device. I am almost positive in saying no you can not do that
11/25/2007 3:00:05 AM •
Philips...
Answered
on Nov 25, 2007
Won't play DVD+Rs
By mentioning that your disks are finalized, I am thinking that you are not creating the DVD in the proper manner. For DVD's to play back on commercial equipment, they have to either be authored, created from a ISO file, or cloned, bypassing the copy protection imbedded in many titles.
Do a Google search on DVD authoring or cloning to learn how to sucessfuly create DVD's that will play back on your home player.
7/14/2007 10:59:56 PM •
Philips...
Answered
on Jul 14, 2007
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
