Philips DVD963SA DVD Player
Problems with Philips DVD963SA DVD Player?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Philips DVD963SA DVD Player RSS Feed
Click here to get instant support from our best Experts!
View More Results for Philips DVD963SA DVD Player
Questions and Unsolved Support Problems
Unsolved Problems for Philips DVD963SA DVD Player RSS Feed
Answer
Hello, How can I get a SACD CD to play it's 16/44K track through the digital out jack? Also, if I... (More)
Answer
when using the unit as a cd/sacd player, the front l & r channels are used. there seems to... (More)
Answer
I'm waiting for my Philips 963SA to arrive. I'm hoping I can use it as a CD transport. I have a... (More)
Find a Manual
Philips DVD963SA DVD Player Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Philips DVD963SA DVD Player
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Aveis Electronics
Aveis Electronics is owned by Daytec Corp. which is solely owned by Daewoo. Their warranty number is 1-877-329-8351.Daytec also has a website. written by polarbear195
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will... written by ginko
If your dvd/cd/disc player is skipping
If your DVD player, cd player or any console or unit that uses a compact disc begins to skip intermittently, please before wasting money on a disc... written by fieldy14
Factory Reset
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down... written by xmarine2847
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the... written by stoneheaded
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then... written by MateusDIY
Owners Manuals
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems... written by stoneheaded
Dish Network DVD Remote Codes
DVD Codes BRAND COMBO CODE Aiwa DVD 634, 694, 751 Alpine DVD 653 ... written by stoneheaded
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Philips DVD963SA DVD Player
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Philips DVD963SA DVD Player
Key Features
DVD Type
DVD Player
Number of Discs
Progressive Scan
With Progressive Scan
Playable Disk Types
CD-RW · CD-R · CD (Audio) · VCD · SVCD · DVD Video · SACD
Playable File Formats
MP3
Video
TV Resolutions
480p (525p) · 480i (525i)
Picture Control
Brightness · Zoom · Contrast · Saturation · Black Level
Video Output System
NTSC · PAL
Video DAC
13 bit / 108 MHz
Audio
Surround Sound
Virtual Surround · Built-In Dolby Digital Decoder · Built-In DTS Decoder
Audio DAC
24 bit / 192 kHz
Dynamic Range
95 dB (DVD)
Audio S/N Ratio
120 dB
Connections
Outputs
Composite x 1, S-Video x 1, Component x 1, Analog Audio x 1, Analog Surround x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1, Composite (via SCART), Audio (via SCART)
SCART Connectors
Output x 1 · Input x 1
Convenience
Remote Control
Yes
OSD
Yes
Parental Control
Yes
Resume Function
5 Bookmarks
Display Dimmer
Yes
Dimensions
Depth
12.4 in.
Height
3.98 in.
Width
17.13 in.
Weight
10.14 lb.
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top DVD Player Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
