When trying to install my Philips HDRW 720 HDD/DVD Recorder,the unit shuts off after searching the...
(More)
When trying to install my Philips HDRW 720 HDD/DVD Recorder,the unit shuts off after searching the available cable channels.It gives a message that it is preparing to configure the TVGuide EPG and asks for your zip code then shuts off abruptly. Any one else had this problem?
hello, i bought this dvd recorder a few years back, i have had no problems with it, the last few...
(More)
hello, i bought this dvd recorder a few years back, i have had no problems with it, the last few weeks even with changing batt. on the remote control, it seems to havw quit working.. we had a problem with roaches in our house and have found some hidden in the remote control for this device.. is there any where i can buy a new remote or be able to do all the functions the remote had on the philips receiver.. The remote works on and off but seems to have problems with having contact with the receiver. please email me @ dcaceckc@shawneelink.net or toolmandave07@yahoo.com
Hi, Does anyone knows how I can get a hold of HDRW720 service CD so I can format my erased hard...
(More)
Hi, Does anyone knows how I can get a hold of HDRW720 service CD so I can format my erased hard drive(philips part number for service CD is: 312278590710)? I have called philips and searched internet will no luck. It is not sold in partstore.com. I only can buy the PC communication cable 312278590017 from them. Any help would greatly appreciated.My email address is p_khorshidi@yahoo.com THANKS
I set the timer to record a program. When it has recorded the program an I want to watch it it ...
(More)
I set the timer to record a program. When it has recorded the program an I want to watch it it turns it self off directly. In the indexwindow a small blue circel whit a c in it. is showing. I have been able to record programs with the timer succesfully for a couple of years and now this problem suddenly appears. When I set the timer a small lock is showing in the top left side. I have tried to find out if there is some kind of childlock but it doesn´t seem to be like that. Really greatful for a solution :-) Harriet
I am trying to find a manual to work out how to operate a ONN DVD rewriteable recorder, the model is...
(More)
I am trying to find a manual to work out how to operate a ONN DVD rewriteable recorder, the model is an SW84 11 HDR I want to know how to record something I have recorded from sky onto the DVD player.
For a *long* time I had to put up with a wonky EPG that would often display empty listings or would...
(More)
For a *long* time I had to put up with a wonky EPG that would often display empty listings or would crash the recorder (power down followed by a red flash from the DVD bay). I recapped the power supply in hopes it was the cheap caps they used - no luck. Fortunately I discovered the fix is relatively easy and (most importantly) dirt cheap! You will need a set of small Torx screwdrivers, a pencil eraser and a sharpie marker (optional but it is a big help). Open the case with the appropriate torx driver and you will see numerous circuit boards with a bunch of white and blue flat plastic ribbon cables. These cables are the cause of the EPG (and possibly other) malfunctions on this unit. Philips in their less-than-infinite wisdom decided to use these cheap and failure-prone alternatives to normal connectors. Pick any of the cables to start with and carefully unplug one end. Grab your pencil eraser and make sure there is fresh (ie uncontaminated) eraser on it. Place the silver end of the cable on a rigid surface that will allow you to hold the cable in place while scrubbing it with the eraser. Scrub the silver contacts with the eraser and try not to let any of the eraser debris fall into the recorder. Wipe off the contacts with a soft cloth to catch the eraser debris and mark the white section of the cable with the sharpie so you know you've cleaned this end. Plug the cable back in and repeat for the other end. Now repeat this process for all the cables in the unit. You probably don't need to do it for the hard drive cable but it couldn't hurt. Just be sure the cable's silver side goes into the side of the socket with the pins. You might want to take a picture or draw a diagram for reference. After this fix, my unit hasn't crashed *once*. Hopefully this will help other Philips DVR owners. Weirdal1968
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
