Meade ETX-70  Telescope
Problems with Meade ETX-70 Telescope?
Troubleshooting and Support
Solved Problems for Meade ETX-70  Telescope RSS Feed Post a New Problem
Azimuth motor gearing problem
Just picked up a second hand ETX-70. When powering up for the first time, Altitude motor movement is ok, but the azimuth...
1 Solution
minor slewing in etx 70
was focused on Saturn night before last and getting a great view, but the scope kept slewing it off (particularly at...
4 Solutions
Bushnell 565
i just dug up my parents 18-20 year old Bushnell 565 telescope. i have no cule how to use it or what was included with...
1 Solution
Celestron NexStar 8 Special Edition
Two questions  -  I have not run my telescope in a long time - but when I through the switch, the hand...
1 Solution
Blown fuses in meade telescope
Hi, thanks for the reply. I don't know if what you said could be the problem.If I disconnect the ribbon from the mother...
1 Solution
Need Telescope Repaired
I have a 200 power telescope that my father built from a kit in 1958. The inside of the tube has had some dirt (like...
1 Solution
mounting bracket
vivitar 50x/100x refractor telescope, the screw on the tripod will not screw all the way into the mounting bracket on...
Post a Solution
Unsolved Support Problems
Unsolved Problems for Meade ETX-70  Telescope RSS Feed Post a New Problem
A part broke on my
A part broke on my Meade 70AZ telescope its on the outside right side its crome and it helps with movement of the...
Post a Solution
slew problem
my etx-60 will only slew down but won't slew up...can hear motor running...any ideas?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Focal Length350 mm
Mount TypeAltazimuth
Optical Diameter70 mm
Max Useful Magnificationx 240
MotorizedYes
Optical DesignRefractor
Meade Contact Information
Main support number(800) 626-3233
Support FAX(949) 451-1460
Sponsored Links
Loading problems.
Top Experts
Ask Me
tonybudz Guru
1 solutions
Ask Me
informati Guru
2 solutions
Ask Me
PaulMo Wiz
9 solutions
Repair Service
Find Telescope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
