20 Most Recent
Medion 9653 Digital Camera Questions & Answers
THE LCD DISPLAYS "CARD LOCKED"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sir,i have medion md 7425 digital camera yesterday
Hello
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Lens error 1114 on my camera
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Medion 9700 digital camera
The problem seems to be in the part of the process of taking picture when the camera scans the scene for brightness, to correct exposure. Bright regions turn greeny blue when taken. Low light images are usually unaffected. The problem can be testes by waving a dark object in front of the camera just before shooting. This implies that the good image result (if over exposed) is not a faulty CCD. It seems that the camera has trouble determining the colour balance or white brightness and tries to compensate by post processing.
I will look for a further solution.
Locked memory card
If your camera uses SD cards, as most likely is the case. There is a little plastic switch on the SD card, you must have switched it. Switch it back.
It is a primitive write protect, it only works if the device checks if it has been switched, the camera will check this.
Where in Ghana can i get a medion camera lense to buy
You haven't stated which model of camera you posses, but from looking at their UK website it appears that they are all fixed-lens cameras, so I think it unlikely you could purchase just a replacement lens or an ancillary one. If the lens in your camera is non-functional, the best idea is to take it to a local service centre to see if it can be economically repaired.
I have a medion model
Sorry, but the only advice I can give you is to step up to a new, modern camera and be careful with it next time.
I have a md 86127
Base from the description of your problem this is a sign of bad battery , that's the unit wont stay on and the battery is always indicating fully charge, so what will be the first thing to try here is to use a different battery and I'm positive that problem will be resolve.
The video works 6 programme
This program seems to have some compatible issues with windows Vista. So if you are using Vista you have to run the program in compatibility mode for windows XP to resolve the issue.
Also let me know the make and model of your camera so that I can provide another solution to get it working.
Sai.
Old traveler camera dc3000 driver download for
your question is not very clear. however if you need to download driver for free you can visit these sites: www.wareseeker.com or www.downloadatoz.com/driver for a download. give a feedback if this solve your problem or helpful. thanks
