Philips Magnavox 20MS3442 20" TV
Problems with Philips Magnavox 20MS3442 20" TV?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Philips Magnavox 20MS3442 20" TV RSS Feed
Click here to get instant support from our best Experts!
View More Results for Philips Magnavox 20MS3442 20" TV
Questions and Unsolved Support Problems
Unsolved Problems for Philips Magnavox 20MS3442 20" TV RSS Feed
Answer
My television is only two years old.It simply shut off and will not come back on.
Answer
philips tv 20" model# 20pt6341/37.tv working with picture & sound. but tv showing on 1... (More)
Answer
I need code numbers for a RCA Universal remote. Model number for the remote is RCR311STN and I need... (More)
Answer
the picture looks as if it's fading away, it's really dark.
Find a Manual
Philips Magnavox 20MS3442 20" TV Manuals & Guides
Tips & Tricks
(Post a New Tip)
My Magnavox TV is showing a feature screen
Press the channel up and volume down buttons at the same time on the front of the tv until the set goes off. When you turn the set back on the feature... written by rusty_etech
Magnetized TV, Poor picture, blotches, discolored, target shaped image
If your set looks like the one pictured above it is likely magnetized and needs to be degaussed (or demagnetizing). All CRT type TV's are prone to... written by johnnydiode
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
DTV transition: Options for Those with Analog TVs
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear... written by Lauren_FixYa
Removing parental lock on RCA and GE TV sets
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method... written by techman
repair job update
Update A number of people have commented that after changing the color wheel, their red and blue colors are reversed. This is a different color... written by sweet_rascal
repair job continued
7. Locate the color wheel cover. It?s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also,... written by sweet_rascal
Purchase a Color Wheel & The Repair Job
My television is model Samsung HLM4365WX and the color wheel part number for that is BP96-00250A. This color wheel is used in many, many Samsung... written by sweet_rascal
WikiManual
(Post a New Chapter)
How to Repair a Remote Control
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Philips Magnavox 20MS3442 20" TV
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Philips Magnavox 20MS3442 20" TV
5
Owners Recommend
out of 7
Reliability
Ease of use
Value for Money
Rate and Review the Philips Magnavox 20MS3442 20" TV
Write a review:
Rate this product:
Would you recommend the Magnavox 20MS3442 20" TV to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Philips Magnavox 20MS3442 20" TV
Key Features
Screen Type
Flat Screen
Diagonal Screen Size
20 inch
Display Capabilities
Aspect Ratio
4:3
Image Quality
Velocity Scan Modulation
Without VSM
Comb Filter
Without Invar Shadow Mask
Audio Features
Audio Type
Stereo
Technical Features
Picture in Picture
Without PIP
Parental Control
Without Parental Control
Sleep Timer
With Sleep Timer
Screen Text
Channel Labels
Without Channel Labels
Closed Caption on Mute
Without Closed Caption On Mute
Dimensions
Depth
18.2 in.
Height
19.3 in.
Width
23.5 in.
Weight
59.5 lb.
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top Standard... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
