20 Most Recent
Olympus IS-50 QD 35mm Point and Shoot Camera Questions & Answers
Camera doesn't zoom or take picture
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
My Olympus VR-340 is not working.
Locate the reset button on your camera, usually found in the battery compartment. Press and hold the reset button for a few seconds, then release it. This action may help resolve any software glitches causing the issue. myreminiapk.com
WHEN I TURN MY OLYMPUS ON IT GOES RIGHT TO "ZOOM ERROR" THEN SHUT OFF. ANY SUGGESTIONS?
When your Olympus camera goes straight to "Zoom Error" and then turns off, it is likely that there is an issue with the camera's lens mechanism. Here are a few things you can try to troubleshoot the problem:
- Turn off the camera and remove the battery and memory card. Then, wait for a few minutes before re-inserting them and turning the camera back on.
- Gently move the lens back and forth with your fingers to see if it can be moved and if it is stuck.
- Use a can of compressed air to blow dust and debris out of the lens mechanism.
- Check the lens for any physical damage such as cracks or dents.
- Try using the camera without the zoom function to see if it still turns off.
- If none of the above steps resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus camera is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
My olympus sz 14 camera shows Zoom error on the screen when I turn it on and then turns off immediately. I bought a new battery a d charged the camera but it continues to shut off.
The "Zoom Error" message that appears on your Olympus SZ-14 camera's screen when you turn it on, followed by the camera turning off immediately, could be caused by a problem with the camera's lens.
- Try gently tapping the camera on a flat surface to try and realign the lens.
- Check the lens for any dirt or debris that may be blocking the movement of the lens. Clean the lens with a soft, dry cloth.
- Check the lens for any physical damage like dents or cracks.
- Contact Olympus customer support: If you have tried all the above steps and the camera is still not working, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to keep in mind that the Olympus SZ-14 is an older model camera, which makes it harder to find replacement parts and professional repair services. If the camera is still under warranty, you may be able to get it repaired or replaced by the manufacturer.
